1978 - 1996 Big Bronco
4x4 issues, switch to manual hubs?
Old 12-10-2005, 11:53 PM
cheifleif's Avatar
cheifleif
cheifleif is offline
Unhappy 4x4 issues, switch to manual hubs?
Just got the truck out of the shop... 94 5.8
When it went in no light, no 4x4.
Mechanic said it was electical problem he Did the transfer case...
Tried it out today, lights come one... pull on to the beach...no 4x4
Get towed out.
i'm thinking a compression problem... when i was doing the plugs last week i noticed a disconected breather hose next to the 1 plug (passenger side closest to cab)... maybe ....
Would it be easier to switch to manual/automatic hubs.
If so what has anyone installed, what to look out for, etc
Surfer in ny the less time out side the better.
Old 12-11-2005, 02:58 AM
aurgathor's Avatar
aurgathor
aurgathor is offline
Automatic manual hubs are the #1 cause, and electric t-case is the #2 cause of non-working 4WD. Jack up the car (all 4 wheel in air) to check if the front shafts are turning in 4HI. If so, the auto hubs are toast. If not, the T-case motor is not working.
Old 12-12-2005, 02:06 PM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
Originally Posted by aurgathor
Automatic manual hubs ....
Automatic manual?? Hmmmmm Thats a new one.
AURGATHOR is right about the Automatic hubs. They are a failure point well known to those of use who had them. Most have switched to manuals and have not looked back. i just replaced my manuals with WARNS about 3 years ago. Love em!
Worth the $$ to get rid of ol' "un" faithful auto hubs.
Old 12-12-2005, 02:50 PM
masseysbronco's Avatar
masseysbronco
masseysbronco is offline
put it in 4 wheel and have someone watch to see if the front driveshaft, and axle shafts are turning. If they are and the wheels are not then your auto hubs are toast (big surprise). Go get manual ones.
Old 12-12-2005, 03:07 PM
aurgathor's Avatar
aurgathor
I guess my brain was toast at 4 AM... Too bad it's a tad difficult to replace, but it can usually be refreshed.
Old 12-13-2005, 08:30 AM
BillyBob69's Avatar
BillyBob69
Don't feel bad.....I just closed out a thread in another forum for some of my work stuff, and posted back...I found the problem!....just read up further to see that someone else already told me the fix. DOH!!!
Cheifleif....Check out EBAY when you go to buy them I got mine new from Ebay and they still have the warranty. Just check on Warn's site first for the model number so you get the right ones.
Old 12-13-2005, 09:47 AM
skelator84's Avatar
skelator84
skelator84 is offline
I bought some manual hubs from oreillys the price was from 75 to 100 dollars. mile marker is the brand, they have been on for over a year and i have had no problems with them yet.
Old 12-13-2005, 11:39 AM
Towmanjbo's Avatar
Towmanjbo
Towmanjbo is offline
During the wintertime have you found any issues leaving the hubs locked while driving around? Meaning switching back and forth between 2 and 4 depending on the snow on the roads. I switched my hubs during the summer first winter this year. Oh btw I have the manual 4wd (floor shift), '93.
Old 12-13-2005, 12:24 PM
skelator84's Avatar
skelator84
I never leave my hubs engaged when im not using the 4wheel drive.
Old 12-13-2005, 02:08 PM
Towmanjbo's Avatar
Towmanjbo
What about when your on the highway in the northern part of the state then when you get to a better plowed area and you want to just quick switch out and continue and speed up. ( i never travel faster than 50 in 4wd)
Old 12-14-2005, 08:15 AM
BillyBob69's Avatar
BillyBob69
Leaving the hubs locked in over an extended period will cause issues. If you are running around in and out of snow under 45, for say......a couple of weeks....shouldn't be a big deal. But over more time, the hubs will wear prematurely. I know there are those out there that will tell you they have gone all season long with the hubs locked in and at highway speeds but it just puts more stress on the hubs, front axels...etc. It is really a matter of preference and use. Should you decide to do this, go with a set that has a lifetime warranty like the Warn Premiums. I know there is another brand out there but I have only dealt with Warns and have had real good luck with them. This way if they fail....you can always replace them and say they went out with very little use.
Old 12-14-2005, 11:17 AM
Towmanjbo's Avatar
Towmanjbo
Ya thats what I used the Warn Premiums. Ok thanks.
Justin
