Small engine dilemas
Old Dec 11, 2005 | 08:01 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
It had a QJ19 LM.
The two I purchased were CJ8's - that could be the issue (I have sanded back the coil assembly, to no avail).
Old Dec 11, 2005 | 11:29 PM
pfogle's Avatar
pfogle
Pull the flywheel and check the points. If they are loose then they can cause problems. Use a matchbook cover to set them. If it's closing the gap on the plug then I'd say you need to get a new motor.
Old Dec 11, 2005 | 11:31 PM
ford390gashog's Avatar
ford390gashog
theres no points on these enignes . they use a magneto.
Old Dec 12, 2005 | 12:38 AM
JD717's Avatar
JD717
no small engine has used points ignition that I know of in many years now. its all solid state electronic ignitions. this sounds definately like something or other is hitting the tip of the plug closing the gap on it. I've NEVER seen that with the proper plug in it, and a J19, or J17, or CJ8 will be just fine for that motor. I cant think of anything that would cause it to close the gap.
Old Dec 12, 2005 | 12:40 AM
ford390gashog
is there any visable damage to the top of the piston?
Old Dec 12, 2005 | 01:06 AM
Ford_Six's Avatar
Ford_Six
IIRC, the plug isn't over the piston anyways, it's in the area between the valves and piston.
Old Dec 12, 2005 | 02:42 AM
pfogle's Avatar
pfogle
The last small engine I worked on was built circa 1967 so you can imagine. But it sounds like there is something not right, the plug is actually over the valves more than the piston. I'd be checking to make sure the valve are the right length. It can wreak havoc if they're not.
Old Dec 12, 2005 | 06:24 AM
GlennFordx4's Avatar
GlennFordx4
Well the plug you have now CJ8(hardware store plug) will work.I have seen one motor like yours have a piece of metal flashing left over from casting the block get stuck in the valves and gave me a hard time tracking down,If you have a local shop around take it there for warranty before you mess it up and then they wont fix it (I am a briggs warranty dealer)I know its something simple unless it ran low on oil It wont cost you anything,If you dont have a receipt they will just use the build code on the motor.The most problems I've had with that motor is carb related and most of the time it was a bad diaphragm or the primer wasn't being pushed enough and some had a little water in it.
Old Dec 17, 2005 | 06:15 PM
BigF350's Avatar
BigF350
FTE Emeritus
Ok I took it back to the place of purchase - where I got sent the local Briggs and Stratton repair agent.
Took it in there, explained my dilema (with the spark plugs closing gap),
He checked the oil, chastised me for only filling it up just past empty, and then proceded to explain that it probably wouldn't be a warranty issue, its probably the wrong fuel or something else I have done...
He said he had "never heard of such a thing" (re spark plugs) - instilled with confidence, I just left it with him, he said he would call me when he works out what is wrong with it.
Will be interesting thats for sure.
RockAuto
Vendor Specials, Discounts, Product Announcements & Group Buys
Jan 12, 2017 10:24 AM
earnhardtracer38
13
Nov 6, 2009 05:16 PM
78bigunns
Dec 12, 2006 06:15 AM
bradmur
Nov 30, 2005 09:00 AM
