front end noise
Old Dec 10, 2005 | 05:07 PM
3carsteve's Avatar
3carsteve
front end noise
i have a 01 f 350 4x4 4 door dually just bought it 2 weeks ago. i just started to notice a clunking noise in the front end only when braking. called ford and they were no help, just wondering if anyone else has herd a noise like this or where would be the best place to look. all nut, bolts,and bushings look good. also i can feel the thump in the floorboard. the only thin i can see is the back side of the front wheels there is a round hard rubber ring ( seal part maybe). any help would be greatly apprecited. S Steve
Old Dec 10, 2005 | 05:35 PM
SpringerPop's Avatar
SpringerPop
Common source for this kind of noise is the sway-bar link bushings.
Check real carefully.
Pop
Old Dec 10, 2005 | 08:13 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 10, 2005 | 08:32 PM
TTye's Avatar
TTye
SAME sound in my 04 F350 CC PSD
Did you figure out what the noise was coming from? Mine is driving me nuts!!!
Old Dec 10, 2005 | 08:42 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
yup, it is most likely the sway-bar link bushings. the bushings that are at the axle/swaybar location. symptoms are clunking/popping noise when cornering, braking, going over uneven surfaces at speed (such as pulling into a driveway or hitting a pothole.) the best replacement is Enerysuspension. they do not have online retailers, but rather local autoparts stores that carry ES parts. the part number is 4-5186, and we have two trucks that have this sickness that i am going to remedy soon.
Old Dec 11, 2005 | 09:33 AM
3carsteve's Avatar
3carsteve
i will check after church. should i jack it up or have my wife turn the wheels or is there a different trick.
Old Dec 11, 2005 | 09:35 AM
3carsteve's Avatar
3carsteve
no not yet will get in there after church
