Sponsored by: Auxito
speed control modification recall
Old Dec 9, 2005 | 10:21 PM
flatrate's Avatar
flatrate
if you havent gone to the dealer yet for your repair, you need to. 2000 model F-150's and Expeditions and some 2001 crew cabs built at kansas plant---you need to go and get the proper repair done....you only have 6 days
Old Dec 10, 2005 | 01:09 AM
paul812's Avatar
paul812
i got a postcard the otherday saying the replacment parts wouldnt be ready until Feb. And all it is is a fuseable link w/a little bit of wire harness...cant be that hard to manufacture....i just unplugged my switch at the master cyl. Already had one house fire, dont need another.....paul
Old Dec 10, 2005 | 10:17 AM
flatrate's Avatar
flatrate
if you have a 2000 model you need to get the repair done. the switch will no longer be replaced on the 2000 models after december 15. the jumper harness will be used...and it is one ugly creature....simple, but very ugly.
Old Dec 10, 2005 | 01:19 PM
bulrydr_1's Avatar
bulrydr_1
My dealer here said that the parts won't be here until mid-december. I am on the contact list with them once they arrive, so for now I just have it unplugged from the master cylinder.
Old Dec 10, 2005 | 05:27 PM
flatrate's Avatar
flatrate
the jumper harnesses are actually in now, but in small quantities. my dealer just got about 50 or so in last week. as far as i tell, it seems to be first come first serve....had one today that had not been even been deactivated yet, but we installed the jumper anyway. my main point was to warn the original group affected by the recall...2000 f150 and expedition. the 15th is the last day of replacing the actual deactivator switch (which is the whole problem), the 16th--everyone gets the jumper harness( ie. the band-aid)
Old Dec 10, 2005 | 06:23 PM
BlueOvalFitter's Avatar
BlueOvalFitter
97 F150
I got my recall notice back in October.I took it to my local Ford dealer and they unplugged the switch.Last week I got a notice saying the part will not be in until Feb.
Old Dec 11, 2005 | 07:11 PM
gunman_sr5's Avatar
gunman_sr5
Trailering
Wow back when the initial recal happened I got in and had the old one removed. It took 2 months and I had the new one in.
Old Dec 11, 2005 | 07:19 PM
A_Freebird's Avatar
A_Freebird
I never got a letter, I called dealer with VIN and took it in the next day on my 2000 F-150. Got the new harness and no prob. waited about 20 minutes while they pulled her around. That was in like July.
Old Dec 12, 2005 | 09:36 PM
zman764's Avatar
zman764
I just toook mine in this weekend I got a letter sayin parts would be in in Novemeber, then a postcard saying they wouldnt be in till Feb.
But they did it, I left hit the cruise it worked, called them and they said They got 30 parts in so i was lucky.
When I opend the hood There is a sitch comin out of the Brake resovoir and a several inch long new piece tie wrapped to a cable just stickin up.
Is this how yalls is?
Old Dec 12, 2005 | 10:06 PM
flatrate's Avatar
flatrate
i told you guys the patch was ugly....i only hope all of you with the 2000 models went and got your switch and jumper . the problem with this recall is what parts are being 'serviced'. the problem with the truck is that the switches eventually leak brake fluid---this leads to shorting the switch out and causing the official "overheating of the harness". its not the ugly harness, but rather the lack of a switch(the cause) that you guys need to looking at. owners of 2000 models were promised switches, now the blame for the recall is placed on "overheating of the harness", so now you get a fused harness---and when the switch starts leaking and the harness goes POOF its your responsibility to repair the problem. sorry to beat a dead horse, but i think that there are too many people out there that dont understand that they are getting the short end of the stick here.
Old Dec 13, 2005 | 12:26 AM
vwboomer's Avatar
vwboomer
I haven't looked under the hood yet since mine was done today, but what's involved in replacing the faulty switch?
Old Dec 13, 2005 | 04:35 PM
flatrate's Avatar
flatrate
replacing the switch is about as easy as it gets. just unscrew it from the master cylinder and install the new one. but prior to installation drip a drop or two of brake fluid into the threaded end of the switch....no bleeding is necessary.
Old Dec 13, 2005 | 10:49 PM
LxMan1's Avatar
LxMan1
I got my letter today from my dealer saying that they has a few (about 2% of what they needed) and that since I had them unhook mine, that I was eligable to have my new harness installed. I go Thursday morning I finally get my cruise back !!
Old Dec 15, 2005 | 12:41 PM
Toby'sFord's Avatar
Toby'sFord
First of all thanks to all for giving the heads-up that the dealerships have the harness in. I called this morning and they had 2 left, so drove in an hour and had it installed. It was mentioned in this thread that if it was done before the 16th, we would get a new switch, which is the problem, then after that it would be the harness with a fuse. Well, today is the 15th and they only would put in the harness. But, maybe they will only replace the switch if it is bad and/or a 2000 model. I don't know... I might have misunderstood what was being said too. None the less thanks for posting that they are available now. I am back cruising down the road!
ascheperle
Oct 23, 2025 10:51 AM
redlightning
Jan 1, 2014 01:24 PM
Bill455
Sep 30, 2013 08:35 PM
