Running Board repair?
Old Sep 30, 2013 | 02:02 PM
Bill455's Avatar
Bill455
Smile Running Board repair?
Does anyone know if you can repair a running board where the bracket has been bent and the running board looks warped?
Old Sep 30, 2013 | 02:53 PM
sammie0126's Avatar
sammie0126
Sure if you remove the bracket and bend it back straight. Are you sure the bracket is bent or is it the metal support is rusted/weak and it's flexing between the brackets?
Old Sep 30, 2013 | 03:05 PM
EXv10's Avatar
EXv10
ha ha .........theres your answer o.p.
Old Sep 30, 2013 | 03:12 PM
Bill455's Avatar
Bill455
The brackets are bent, the plastic is in good shape but the metal support is tweeked due to the brackets being bent. If i remove the brackets ii'm hoping the plastic will go back to its original shape?
Old Sep 30, 2013 | 06:19 PM
EXv10's Avatar
EXv10
Probably, give it a try.
Old Sep 30, 2013 | 08:35 PM
fordboy2's Avatar
fordboy2
Ford shows the bracket available separate too. If there still available anyways.
Jersey Sierra
May 17, 2018 07:18 PM
beefcake
Dec 11, 2010 01:35 PM
ALBUQ F-1
Nov 7, 2005 09:16 PM
dj53
May 4, 2005 08:25 PM
