Hard Starting
Old Dec 9, 2005 | 10:12 PM
Panzerbrumbar's Avatar
Panzerbrumbar
Hard Starting
I have a 00 Expy and I have an Astro Start remote starting system. And even after the astro trys to start it I will go in and try to start it will not go. IT has been cold here lately around zero. It turns over okay but it will not start until I run the foot pedal. I was thinking of a throttle postion sensor or Idle Air Control. I should know more since stepped down from a V10. I have done a search but could not come up with anything. Any help would be great. I am a wrench puller but I work on Cat and Komatsu stuff so I am a little out of my element thanks for any help.
Old Dec 9, 2005 | 10:32 PM
PaulC's Avatar
PaulC
IAC is a good suspect. They tend to act up when the temperature drops.
Old Dec 10, 2005 | 03:12 PM
Panzerbrumbar
Well I think I got it the problem fixed I guess I will be one hundred percent sure when it gets cold out. I had to buy it from my dealership ship since no one had it in town. I tried running the old one and it just stuck until I pushed then it moved so I hope the problem is done. It does idle alot smoother so lets hope. T
