E4OD to S5-47 ZF
Old Dec 9, 2005 | 06:07 PM
jimkidd's Avatar
jimkidd
E4OD to S5-47 ZF
Will the bell housings bolt up for a E4OD to S5-47 ZF swap? Anybody know how much an S5-47 ZF tranny for a 4x4 costs? or what else will have to be changed? Is it just a "bolt in" change over?
Old Dec 9, 2005 | 07:26 PM
wycowboy's Avatar
wycowboy
Yes a zf-5 wil bolt up the your engine ,, There are two differn zf-5 one for gas and the other for diesel. they have dierent gearing. if you look around you can get a remaned zf-5 for 1200-1500 or so.
you will need hydrolic clutch cyilndres a cultch, flywheel, peddal ays. form what
Ive found out this is not too hard of a swap I'm looking at doing it my self. J
Old Dec 9, 2005 | 11:42 PM
hucka1a's Avatar
hucka1a
Let us know how it goes, I'm wanting to swap mine also(the only problem I had with my truck in 242,000 miles is the E4OD)
Old Dec 10, 2005 | 06:46 PM
jimkidd's Avatar
jimkidd
Read this:
http://www.jimkidd.com/FORD/STJ73B01.pdf
According to this the gears start lower and end higher for a gas engine.
Right?
Would that be OK, assuming the onboard computer could be programmed correctly?
Is there any other reason not to use the gasoline version?
According to the note at the bottom "For vehicles equipped with the 7.3L diesel engine, this transmission requires use of synthetic MERCON® Multi-Purpose Automatic Transmission Fluid E6AZ-19582-B or MERCON® equivalent meeting Ford specification ESR-M2C163A2." If I use the gasoline version will I have to change over to this VERY EXPENSIVE (I know about this ) Syn ATF Fluid? (Why do they use ATF fluid in a manual trany?
Will the cruise still work?
That enough for this time.
jimbo
Old Dec 10, 2005 | 10:32 PM
wycowboy's Avatar
wycowboy
you wont have to worry about the computer it dose not care what you have..
reasons not to use the gas version are if you have a 4.10 rear gearing it wil make first soo low as to be only useful with a vrey big load or off roading. 2 the jump from 3rd to 4th is big. and you will wish you had a gear in between.
If you have a3.55 rearend Ithink it would work quite well you still have big jump from 3dr 4th but it will give you a great low end and still enkoy the 3.55 an the hi-way'
the reason for atf is the it dose well wht heat,, is thiner for smother shifting and is used in all tranys with aluminuim hosings like the zf-5 ...J
Old Dec 11, 2005 | 04:51 PM
jimkidd's Avatar
jimkidd
I thought you had to reprogram something to keep your speedometer right.
Also, will I have to change anything to keep the cruse control working?
Old Dec 11, 2005 | 05:18 PM
wycowboy's Avatar
wycowboy
Hummm.. I'm not sure about the CC.. you could be right. I'll look in to it.. J
Old Dec 12, 2005 | 08:21 AM
jimkidd's Avatar
jimkidd
I found a ZF for $900 delivered. 79,000 miles, 90 day guarantee. Is this a good deal?
Old Dec 12, 2005 | 04:28 PM
hucka1a's Avatar
hucka1a
sounds good compared to $2100.+ $500 core for a reman from advance auto
Duelly7.3
May 21, 2016 08:04 PM
wtroger
Mar 26, 2015 10:45 PM
travis.k.hirt
Jan 12, 2015 04:55 PM
f300i6
Aug 7, 2014 04:25 AM
