Offroad & 4x4
Weight?
Old Dec 8, 2005 | 08:45 PM
FritzBlitz's Avatar
FritzBlitz
Weight?
How much weight do you guys got in the bed of your trucks? I put 420 pounds of sand in the bed, plus my toolbox, but im still sliding a bit. I have brand new BF Goodrich All Terrains, also.
Old Dec 8, 2005 | 09:31 PM
FritzBlitz's Avatar
FritzBlitz
I am talking about snow, if any one was wondering.
Old Dec 8, 2005 | 09:43 PM
racsan's Avatar
racsan
300 pnds, running nearly bald goodyear wrangler rt/s 215-15s. actually get better traction than my summer wheels with 6-year old bfg long trail t/a's (with decent tread)
Old Dec 8, 2005 | 09:49 PM
FritzBlitz's Avatar
FritzBlitz
Where do you place the weight, over the axle, towards the front of the cab or the end of the bed?
Old Dec 8, 2005 | 10:31 PM
racsan's Avatar
racsan
130 pnds is in a sand filled spare tire in the stock carrier, behind the axle, the remaining weight is in a 3/4 ton tire assy (sand again) right over the rear axle between the wheelwells.
Old Dec 8, 2005 | 11:01 PM
aurgathor's Avatar
aurgathor
You should put the sand to the very end of the bed in a 2WD truck; also, there are lots of differences between snow and snow. IMHO, the worst is the one that falls on a relatively warn road, then piles up a couple of inches, so there is a snow covered slush.
Old Dec 9, 2005 | 12:37 AM
mustange70's Avatar
mustange70
What psi are the tires at? Might want to drop them down to the 25-28range for a bit softer contact patch.
Old Dec 9, 2005 | 02:02 PM
FritzBlitz's Avatar
FritzBlitz
Yea I was thinking about that, there at 33-35 right now, but I dont want to lower them now becasue when im driving on the street it will hurt my tread wear, so I guess when the next big snow storm hits I will.
Old Dec 9, 2005 | 10:40 PM
mustange70's Avatar
mustange70
taking them down to at least 30 shouldn't hurt tread that bad.
Old Dec 10, 2005 | 08:12 AM
racsan's Avatar
racsan
remember outside temperature will affect tire pressure. if you air them up to 30 at 70 degrees and dont do anything more, at 25 degress the tires could be at 20 psi (i forget the formula for pressure drop vs ambeint temperature) it makes it hard to choose a specific pressure, the temp has floated here lately from 0 to 28, its 19 right now.
Old Dec 10, 2005 | 08:16 AM
The SnoMan's Avatar
The SnoMan
I do not agree with the reduce pressure. I have had better luck with higher pressures.
Old Dec 10, 2005 | 11:06 AM
{OF}Smiley's Avatar
{OF}Smiley
Sliding a bit with the rear is not a bad thing, if the rear gets more traction that the front you can end up pushing the front tires instead of having directional control. Every vehicle has different needs, it depends on many factors such as tire width, tire tread, open or LS or locked diff, vehicle weight bias, etc. A dually will need a lot more weight than a single. I always put the weight at the rear of the bed, you need less weight that way to get the same added grip. I normally experiment in 100 lb increments until the rear has slightly less grip than the front.
One thing to try, if your truck has the spare under the rear on a cable, drop it down and place a couple of those 25 lb weight lifting weights in the wheel, put the lift cable throught the center holes in the weights and then through the wheel. Be careful winding the tire back up into place as you have about doubled the weight for the little winch to lift This adds 50 lbs nice and low at the rear of the truck and this weight will not shift around in the event of an accident. Be careful what you place in the bed for weight, it can be come a projectile and go through your rear window in a front end collision. That might hurt . . .
Old Dec 10, 2005 | 11:22 AM
rebocardo's Avatar
rebocardo
In my 1997 Ranger (4x4) for snow and ice I use to air down to 20 psi, for the snow storm, and keep 600 pounds of sand bags (laid even inside green bags) in the bed for winter. Pretty much go anywhere even with Firestone Wilderness ATs.
As for lower pressures, what gives more traction, a hard round wet slippery donut or a softer tire that will conform to the irregular surfaces of the road and ice without spinning. A great plus is a radial tire will spread out and grip a lot more then a bias in snow and ice and the sides will give a lot more traction.
Old Dec 10, 2005 | 12:27 PM
tjc transport's Avatar
tjc transport
i ain't rite
maby so, but then again, i have yet to see you agree with anything anyone has said.
Old Dec 11, 2005 | 02:04 AM
mustange70's Avatar
mustange70
35psi vs. 25psi (assuming both would have something like 400lbs of weight in t he bed) will make a big difference, granted it might not be as noticeable in some vehicles, but imangine one of those rubber laytex gloves, blow it up and fingers get hard and smooth (thus providing no grip), compared to a rubber laytex glove that just has enough air to give it shape, the fingers are soft and grippy (thus more traction) the same holds true for a tire (they are made out of fairly similar compounds too).
90pioneer
Aug 8, 2014 12:25 PM
f100today
Dec 13, 2013 01:41 PM
baitbucket
Mar 20, 2007 07:54 PM
danray35e
Jul 12, 2006 12:09 PM
1986F350witha7.3
Jun 30, 2006 09:53 PM
