Rocker arm bolts
Old Jan 14, 2002 | 06:48 PM
BB's Avatar
BB
Rocker arm bolts
Old Jan 18, 2002 | 11:50 AM
DutchmanAZ's Avatar
DutchmanAZ
Rocker arm bolts
I just replaced a blown head gasket on my '76 F150 4X4 360 motor.
I had to take both rocker assemblies off to get the pushrods out in order to pull the intake to get to the heads.
After all the work was done, and trying to bolt back on the rocker arm assemblies, the 2nd bolt from the back on the driver's side wouldn't go in all the way. I understand that this bolt is differnent (something to due with oil supply), but I just took up the extra space with washers enough to tighten it down. I watched it run without the valve covers on, and that side has a LOT more oil than the other one. Does this matter? The other side is lubricating, but not nearly like the other one.
I still don't know why the bolt wouldn't go all the way in. I couldn't see any obstructions in the hole, and that same bolt fit the other side (same location) just fine.
Any thoughts on this?
Thanks in advance!
Old Jan 18, 2002 | 02:44 PM
Mil1ion's Avatar
Mil1ion
Rocker arm bolts
When you had all the bolts out and together ,Were they ALL the Same Length ?
It sounds like you might have inadvertently put a short bolt in a deep hole and tried to put a long bolt in a short hole.
Dennis
Oh....Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Jan 18, 2002 | 02:57 PM
DutchmanAZ's Avatar
DutchmanAZ
Rocker arm bolts
Actually, I left the bolts in the rocker arm assembly, but those 2 were a touch (1/4 inch or so) longer. From what I read in Steve Christ's book, they're supposed to be (at least in the 2nd hole from the firewall). Again, that bolt fit the other side just fine (and only in that hole) but wouldn't tighten up all the way in any other.
Thanks
Old Jan 18, 2002 | 07:10 PM
tomridge's Avatar
tomridge
Rocker arm bolts
My copy of Steve Christ book says long bolt goes in the second hole from the front on the left side and second hole from the back on the right side.
Good luck
Tom
