Totally Confused
Old Dec 10, 2005 | 12:46 PM
87 XLT's Avatar
87 XLT
When you turn the key to run the computer grounds the wire from pump relay & turns on the pump circuit..
If he runs the jumper as shown at the link & the pump runs, the problem is a break in the wire between the computer & the relay or a bad computer or no power to the computer.
Old Dec 10, 2005 | 12:57 PM
RangerPilot's Avatar
RangerPilot
When you turn the key to run do all the dash check lights come on? If not then it's a computer power problem.
Old Dec 10, 2005 | 04:59 PM
probedude's Avatar
probedude
Are there fuses anywhere for the computer that may be blown? I agree with Jbabbler - it sounds like your ECU isn't alive, hence isn't firing the injectors. The spark control module works independently which is why you're getting a spark, and you've confirmed your pump works fine. You don't have a "pump isn't turning on problem" - your pump isn't turning on because your ECU isn't happy about something (sensor), is dead/bad, or isn't being powered.
Old Dec 11, 2005 | 12:47 AM
mike_23us's Avatar
mike_23us
ok this just happened out of the blue. before i replaced the pump the first thing i checked was the fuel cutoff switch so thats no the problem. and i run a 12v jumper wire within the fuel pump relay the fuel pump runs and when i crank the engine it still runs and still doesnt start. and yes now with the new pump i get 40psi with the old pump i got 22psi and the reason i posted it twice is that im just really wanting to get it fixed. and taking it to the shop is not a option. thank you guys for all the imput even though i kind of make it confusing. thanks
Old Dec 11, 2005 | 12:50 AM
mike_23us's Avatar
mike_23us
is there a way i could check power to the computer tommorrow when i work on it again ill give more info
Old Dec 11, 2005 | 02:35 PM
RangerPilot
Look at what I said in my first post.
Old Dec 12, 2005 | 01:08 PM
mike_23us's Avatar
mike_23us
just a update, i overlooked it at first but i know thing i know the problem i just dont know whats causing it. the #8 fuse the PCM fuse 40a blows everytime i turn the key on.
Old Dec 12, 2005 | 02:26 PM
ckeezer's Avatar
ckeezer
sounds like a sort in the system?!
Old Dec 12, 2005 | 05:06 PM
RangerPilot
Yeah no current draw would change on that fuse, sounds like a short somewhere.
Old Dec 29, 2005 | 11:31 PM
JimCT's Avatar
JimCT
Similar issue in 88 F-250 5.8 L
Originally Posted by mike_23us
ok this just happened out of the blue. before i replaced the pump the first thing i checked was the fuel cutoff switch so thats no the problem ...snip
<snip>... and taking it to the shop is not a option. thank you guys for all the imput even though i kind of make it confusing. thanks
(This is my first post to FTE, please bear with me if I didn't post properly )
I've checked my EEC Power Relay and Fuel Pump relay and they're good (also installed replacements before I tested the old ones on the bench -- no success in starting/firing off the fuel pumps).
I think the fusible link (the heavier brown wire with a little yellow stripe) is good going to the EEC Power Relay, but I have a sneaking suspicion that the wire is damaged in the harness. Tried to do a continuity test through the insulation just after the fusible link to the relay wiring harness, but I can't do it myself. I have to get somebody else to help me make sure it's a continuity problem.
I'm relatively new at vehicle electrical wiring. I dont see any breaks where I can see the wire, but is it unusual to have wires break in the wiring harness in a vehicle that's 18 years old? The harness seems to route from the starter relay over the radiator, under the coolant recovery & air cleaner and then it's very difficult to trace it after this. when it gets near the firewall and ECM.
Thanks
-Jim
- Side note for testing relays: I applied about 5.5 V from batteries to the relays' small pins and heard the relay close the circuit for the big pins. I then measured continuity across the big pins. I needed alligator clips to do this by myself. I believe the computer fires the relay and usually it delivers about 5V DC so that's why I did the 5.5 Volts with a couple of D cells in series.
</snip>
Old Dec 30, 2005 | 07:10 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Jim, to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 30, 2005 | 04:50 PM
Ken00's Avatar
Ken00
Jim,
It sounds like you tested the relay OK. With a vehicle that old a wire could get damaged, even in a harness.
We have a forum for F series trucks, they may know if this is a common problem, see the link below.
https://www.ford-trucks.com/forums/f...splay.php?f=28
milehieagle
31
Apr 24, 2021 06:26 AM
bozo4ford
Electrical Systems/Wiring
Oct 10, 2012 05:12 PM
bozo4ford
Oct 6, 2012 07:47 AM
fast2174
Sep 17, 2010 12:12 PM
