Maximum Boost Range per Ford Specs
Old Dec 8, 2005 | 01:17 PM
beetlebarn's Avatar
beetlebarn
If any Ford Diesel Tech is reading this, could you please tell me the max boost range for a 2005 and where the reference is for this info. Thanks
Old Dec 8, 2005 | 02:26 PM
juniorf350's Avatar
juniorf350
i have registered over 30 but thats with a innovative boost race tune.
Old Dec 8, 2005 | 07:59 PM
beetlebarn's Avatar
beetlebarn
Boost
Mine usually is around 28 to 29 depending on the outside temp. Dealer is saying the boost is too high and is causing the CAC tube to leak - cannot convince them of installing TSB 05-22-3 to replace plastic tube. They want to decrease boost starting with replacement of the VGT and if boost is still to high to replace the turbo. What a bunch of fertilizer! Yes it is stock - got a MBRP and gauges, but that is it. Oh, I do run Standayne Performance Blend.
Old Dec 9, 2005 | 08:48 AM
juniorf350's Avatar
juniorf350
if i was you i would buy the plastic tube and put it on my self.
they replace the vgt and reflash you will lose power.
Old Dec 9, 2005 | 09:54 AM
Bear Hunter's Avatar
Bear Hunter
I believe 27 is about the avg for max unloaded.
Old Dec 9, 2005 | 10:03 AM
beetlebarn's Avatar
beetlebarn
Junior F350 - got the platic tube. I tightened the clamp at the bottom of the airfilter box - got a lot of turn on it fairly easily. Did have a lot of oil residue on the bottom so perhaps this was the cause on the drivers side. Agree on the reflash and VGT - it aint gonna happen. There are numerous ford dealers around that certainly should beable to do better.
Bear Hunter - thanks - guess I'm a little on the high side at 29.2 - but today the max I observed was 28.5. I'm Using the BD monitor that keeps track of max observed.
Old Dec 9, 2005 | 02:07 PM
Jvrobel_30's Avatar
Jvrobel_30
I have seen as much as 34 on my mechanical gauge and a high of 33 on my bullydog outlook monitor. but i also have an intake exhaust and triple dog power pup downloader. very happy with all of the bullydog items unlike most people.
Old Dec 9, 2005 | 04:00 PM
Bear Hunter
The figure I gave was for a stock 6.0...if your chipped you will see about 32 on average (6.0)
