How difficult is it to repair/replace the gear that the cable attaches to?
1979 F-250 4wd manual trans. The cable works fine, but where it connects to the tranny area, after removing the stay bracket.. I look in the hole and it looks like the 'worm' gear is worn inside the tranny . It looks like it is nylon or something. Any ideas of how labor intensive??
The cable should go to the transfer case on your truck.The gear is plastic and isn't to hard to get to.You will need to remove the driveshaft and the yoke,then take of the rear cover.It will slide of the shaft.
Dennis
1979 F-250 4x4 460 4-speed 33"s
1977 Highboy 429 4-speed 35"s
1969 Ranger on a 1978 F-250 4x4
frame 466 560HP 4.10's 33"s
