Front Suspention Sag
Old Jan 20, 2002 | 07:35 PM
Trailor Special's Avatar
Trailor Special
Hi, this is my first post on this forum, great site.
I have a 77 F150 Ranger that came with a factory 460/C6, the front end is sagging from age. It is a 2wd, so it has IFS with coils. Is there anybody who sells coils that will lift the front end about 2 inches, to be more level with the back end?
Thanks for any help.
P.S.- Here is a picture of the truck
[image]http://www.mlode.com/~stuka/Ford-F150.jpg[/image]
Old Jan 20, 2002 | 08:11 PM
Mil1ion's Avatar
Mil1ion
Welcome to FTE!
Congratulations on posting in the correct forum too!
Nice looking truck
MOOG sells Front coils for your truck.
Contact your local auto parts place that sells MOOG.
Maybe do a MOOG search on google to look up your EXACT application.
Does your truck have A/C ? It makes a difference.
Dennis
Oh....Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=144&.jpg
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=143&.jpg
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Jan 20, 2002 | 08:17 PM
Trailor Special
Ya it does have AC, although the belt is currently off.
The truck is all original, hasent been repainted or anything, interior is nicer then the exterior. Also came with a factory 5/8 ton suspention, class 5 hitch, and a LSD (still working. Although its a 8" axle i think, which is kinda surprising.
But anyways, thanks, I will take a look.
Old Jan 20, 2002 | 08:43 PM
Mil1ion's Avatar
Mil1ion
Here is the application site for your truck.
http://209.164.4.4/cgi-bin/sewse?/u/www/webepc.com/cmm/scripts/epc10.cmm
Here is a great site for looking up applications for auto parts
http://www.rockauto.com/
HTH
Dennis
Old Jan 21, 2002 | 12:28 PM
dfisher1's Avatar
dfisher1
Trailer,
Almost everybody sells coils for your Twin I-beam suspension. The question is, "Which coil do you need?" You cannot just compare your old coil to the replacement. The old one will be taller. Strangely enough, once a coil is "Sprung" it will sag and appears taller when removed from the vehicle.
I've found that F150 front coil seems to be a good replacement, in general. There is a cargo coil which is a little taller and much stiffer but, I think it was made for a U-haul application or something.
After you replace your coils take your truck to an alignment shop and check your caster. That is, does the tire lean in or out of the wheel well. It should do neither. Caster at 0 degrees is optimal and a slight negative caster can be tolerated. Positive caster, tire leans out of wheel well, is incorrect and can cause handling problems.
Get a pro to look at the rest of the front end during alignment. I'm sure you'll hear it all. Check the following:
1. KingPin Bushings
2. I-beam bushings
3. Tie rod ends
4. Drag link joint
5. Pitman Arm joint
6. Steering Gear Play
After that, your finished!
My Way is the Highway
KingFisher
Old Jan 21, 2002 | 01:25 PM
karlsd's Avatar
karlsd
mossyoakford96
Mar 13, 2012 12:27 PM
Reviveourhomes
15
Jul 14, 2006 02:01 PM
92stx
1983 - 2012 Ranger & B-Series
Feb 10, 2006 09:31 AM
black-bronco
1978 - 1996 Big Bronco
Feb 12, 2003 01:57 PM
canadianfordman
Aug 5, 2001 04:05 PM
