Explorer Door/Lock Woes!
Old Dec 7, 2005 | 03:57 PM
slbdives's Avatar
slbdives
Have a 97 Ford Explorer that I'm having driver side door problems with. I can't unlock the door with my key and my door handle has a lot of play in it. The handle doesn't act like it's opening the latch until the very last part of the upward stroke. A friend is having a similar problem so thought this may be a common issue? Any suggestions out there?
Old Dec 7, 2005 | 10:45 PM
98xlt's Avatar
98xlt
I suspect its the small springs on the inside of the door handle that keep downward tension on the handle, there are two of them. I'm down to one on my own driver's side door. Both of yours must have finally gone out--a little leg of the spring snaps off. your door probably unlocks, but the handle isn't catching and lifting the latch. The darn assemblies are split riveted on the inside of the door, so I don't know how you could go to a junk yard and retrieve a part that you could install on your door. I haven't priced the part yet myself.
