Tow package???
Old Dec 7, 2005 | 01:34 PM
white 01's Avatar
white 01
Tow package???
What does the tow package consist of? Radiator?, Engine oil cooler ?I have a 97' F-350 7.5 460 w/o tow package.But it does have the camper package what does the camper pkg have?
Old Dec 7, 2005 | 06:29 PM
handyman43358's Avatar
handyman43358
Im not sure about the camper package, but the towing package on my f-150 consists of the helper leaf spring in the rear, oil cooler, bigger rad, and some other things im forgetting. I think it came with factory wiring for trailer brakes also.
Old Dec 7, 2005 | 07:26 PM
dhag911's Avatar
dhag911
a transmission oil cooler
Old Dec 8, 2005 | 09:47 PM
duc_grrl's Avatar
duc_grrl
Originally Posted by white 01
I have a 97' F-350 7.5 460 w/o tow package. But it does have the camper package what does the camper pkg have?
I read in a post in the New Ford Buyers forum that the camper package includes everything in the tow package as well as something else (which I can't remember). So if that was true in 97, you could say that your truck does have the tow package as well as the camper package ...
Also I don't think the F350 has extra springs in the tow package, because my 99 didn't, even though it had the package. After all, it's already a one ton ...
Old Dec 8, 2005 | 10:32 PM
ws595's Avatar
ws595
My '92 F150 tow package also came with a 4.10 limited slip rear-end.
-R.
Old Dec 9, 2005 | 08:09 AM
jroehl's Avatar
jroehl
My '93 F250 has the camper package. LS was not part of it, but I think the 4.10 gears were. After what I drove through last night, I'm going to look into putting in LS soon, I think...4-6 inches of snow can turn a 50 minute drive into almost 2 hours on back highways. Yuk.
Jason
Old Dec 9, 2005 | 03:12 PM
white 01's Avatar
white 01
MY truck has 4.10s and rear lsd,but it has a after market hitch from uhaul not a factory ford.I wonderd if it has the supercooling on it how do i tell?I bought the truck used and the guy gave me the order sheet w/the camper pkg marked.but it doesnt have a sliding rear window,it has the offroad pkg,and front and rear swaybars.
Old Dec 9, 2005 | 04:58 PM
handyman43358
I believe the super cooling package gives you a thicker than stock radiator. I think I read on here that it was 2 or 2 1/2 inches thick, but I could be wrong. I would guess that the oil cooler become a part of that super cooling package. If you lay down underneath the front of your truck and look at the lower radiator hose, and trace it away from the rad, you should eventually see two smaller hoses feeding into the radiator hose. Thats where oil is pumped through the cooler radiator hose (cooling your oil).
Old Dec 10, 2005 | 01:42 AM
jcp123's Avatar
jcp123
We were sort of going over this in a Bronco thread...I'm somewhat mystified because I have the Ford trailer wiring harness and the front dual shocks, but of a frame hitch, 4.10's, LSD, or trans cooler there is no trace.
Old Dec 10, 2005 | 01:50 PM
handyman43358
I've got the factory harness, front dual shocks, a hitch and a trans cooler and thats it. Stock 3.55's. Although I wonder if this has a Posi rear end, because I've NEVER only had one tire spin. Even on dry pavement. Maybe I have that special 3.55 rear end...
Old Dec 10, 2005 | 08:52 PM
k460's Avatar
k460
My 94 3/4 ton 4X4 460 5pd has the trailer brake harness, reciver, super rad., oil cooler reciver, 4.10 limited slip, but no helper springs ?
Old Dec 10, 2005 | 08:53 PM
k460's Avatar
k460
My 94 3/4 ton 4X4 460 5pd has the trailer brake harness, reciver, super rad., oil cooler reciver, 4.10 limited slip, sway bars,
