Sponsored by: Real Truck
Cold starting problems
Old Dec 7, 2005 | 11:26 AM
merkur22's Avatar
merkur22
Help. My 01 f250 does not want to start below once temps get below 20 degrees. Cranks fine, hits, but dies. This progresses as temps dip lower. (took 45 cranks this morning.) Once it starts, it runs fine. I was able to get it running this morning with foot on gas, but it sounded and smelled like crap for about 45 seconds. Then it all of a sudden smoothed out and stayed running on its own. This is 3rd year for this. Any thoughts or suggestions?
Merkur22
Old Dec 7, 2005 | 11:46 AM
FortyFords's Avatar
FortyFords
Change the IAC if it starts every time with your foot on the go pedal.
Also chk for codes with a scanner.
There are other things but this is the most common.
Rich
Old Dec 7, 2005 | 12:06 PM
merkur22's Avatar
merkur22
did that and also changed coolant temp sensor. need to buy code reader, i guess. thanks.
karl
Old Dec 7, 2005 | 12:18 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
What engine are we talking about? Are you getting fuel/gas flow thru fuel filter or air? Wondering if fuel going back to tank after sitting.
Old Dec 7, 2005 | 12:52 PM
FortyFords's Avatar
FortyFords
karl
Okay you will need a fuel pressure chk at the fuel rail.(fuel pump chk valve or fuel reg)
Dirty maf
TPS
You say it smelled,maybe like rotteneggs kinda rich
Rich
Old Dec 7, 2005 | 01:02 PM
merkur22's Avatar
merkur22
more like mothballs, and when i let off the pedal, it died.
Old Dec 7, 2005 | 01:04 PM
merkur22's Avatar
merkur22
is the gas tank s'posed to stay pressurized? maybe bad cap?
Old Dec 7, 2005 | 01:07 PM
FortyFords's Avatar
FortyFords
HMMMMMMMMM interesting maybe bad fuel (water )
You buy your fuel same station all the time?
Ask around maybe other people having same problem.
I'm just throwing things out there for you to think about.
Rich
Old Dec 7, 2005 | 01:11 PM
merkur22's Avatar
merkur22
buy gas at various stations. however, this is the 3rd winter, never when above freezing.
allpro wants 2 bills for a scanner . wew.
Old Dec 8, 2005 | 07:44 AM
merkur22's Avatar
merkur22
Thanks for all the suggestions. I installed another IACV last night. Also went by a national parts chain store to have them pull codes. None. Didn't think so. Anywho, make a short story long, I aprehensively tried to start the truck this morning. (6 deg.)
Fired right up. Wohoo. Not sure if the valve did it or if my fiddling with the connector for the temp sensor has anything to do with it. I'll sort all that out wben it gets a bit warmer; say May.
Thanks again and I'm glad to have found this wonderful resource.
merkur22
Old Dec 12, 2005 | 03:12 PM
johnnynegaunee's Avatar
johnnynegaunee
What's a IACV for us know nothings?
Old Dec 12, 2005 | 03:13 PM
johnnynegaunee
What's a IACV for us know nothings? And where is it?
Old Dec 12, 2005 | 05:19 PM
dantepost's Avatar
dantepost
Had the same problem, changed my IACV and it runs great. The garage was going to charge me 100.00 in labor, for two damn screws. Now I can go out in the morning start it up and sprint back inside for it to warm up.
Old Dec 13, 2005 | 11:57 AM
merkur22's Avatar
merkur22
Believe it stands for Ignition Air Control Valve. It is located behind where the air enters the intake manifold. It has 2 screws which are easily removed from the driver side. The hose, however, is easier to pry off and reconnected from the right side. Took me 15 minutes and the valve was $60.00.
Truck starts great.
merkur
Old Dec 13, 2005 | 12:42 PM
FortyFords's Avatar
FortyFords
IAC = Idle air control valve,its the air bypass when the throttle plates are at idle position.
Rich
jacko,s56 f100
Oct 21, 2011 10:16 AM
jacko,s56 f100
Oct 21, 2011 06:54 AM
HillbillyRockstar09
Virginia Chapter
187
Apr 1, 2011 10:28 AM
AutoPartsExpert
Vendor Specials, Discounts, Product Announcements & Group Buys
Nov 18, 2010 03:52 PM
Harold Graham
Jul 24, 2010 04:59 PM
