Hey guys,
I posted this under "Electrical" as well.
My '77 was running after swapping in a 351W in place of the 400 and now it won't start. I had it running pretty well, came back after a week and now it won't start. Timing looks about right, spark detected at each plug wire. Spark coming out of the coil is extremely weak, even after replacing it. What should I check? There's not much to it I know, Ign. module, reluctor, pickup, cap, rotor, wires plugs, battery, solenoid, starter. So I wonder which one(s)??
Kenny
I've got two spares now, I believe the guy looking at it tried one of my spares. I'kk see if I can get all three tested.
Any thing else? I've had trouble with the pickup in a different Ford truck I had. Anybody know how the pickup and reluctor affect the amount of spark I'm getting?
1)with the ignition off, carefully insert a small straight pin in the red module wire. Measuer battery voltage at the battery. attach a negative voltmeter lead to the distributor base and positive lead to the straight pin.
2)turn ignition swithc to RUN position. measure voltage at the straight pin in the red wire. record the voltmeter reading, turn ignition off and remove straigh pin.
3)the voltage at the pin should have read at least 90% of batter voltage. If it's not, check the resistance wire to the ign/switch, resistance in the wire should be between 1 and 1.1 ohms
That is a better idea....I was going to say run a jumper wire from the battery direct to the coil + and see if it made the spark better
Sparky
>Do a control module voltage check,
>and 1.1 ohms
It's like the big white ballast resistor mounted on the firewall you may have seen on older vehicles. It drops the voltage to the coil down to approx 9 volts while the truck is running. The newer vehicles with a duraspark usually use a special resistance wire than is included in the harness under the dash. This resistance is bypassed during cranking to give a hotter spark for starting.
