99 explorer cold start problems
Old Dec 7, 2005 | 10:23 AM
sumdig's Avatar
sumdig
My 99 expl has runs very rough and idles erratically during start up. I've read the this could be an IAC valve prob. I have got a lean code from the OBD II. Does anybody know if the IAC would cause a lean code or could this be an Intake manifold issue? Just replaced O2 sensors, so they are good. Don't want to replace the IAC unless it's bad.
Old Dec 7, 2005 | 11:31 AM
bulldog3531's Avatar
bulldog3531
You can try cleaning the IAC first. After your truck starts and it is warm does it idle fine? If it does you proberly have the Intake Manifold O-rings problem. And yes both will cause a lean code.
Old Dec 7, 2005 | 11:36 AM
sumdig's Avatar
sumdig
After it is warm it's fine. How hard is it to change the intake manifold o rings?
Old Dec 7, 2005 | 03:17 PM
oshoguno's Avatar
oshoguno
Definately sounds like the intake gaskets. I did mine during the summer and there is a huge difference in cold starts from last year. They are a pretty involved job and if you aren't a mechanic, or consider yourself equal to a mechanic, it is probably a job for a shop. Expect a $400 bill for the work, just a rough guess.
Old Dec 7, 2005 | 08:12 PM
bulldog3531
As Oshoguno said, it is pretty involved job, A friend of mine and I did it on a Sat. morning took about 2 hours. Definately started better when it got cold.
Old Dec 7, 2005 | 08:45 PM
sumdig's Avatar
sumdig
Thanks for your help fellas. Now I gotta decide what I want to do.
