That's impressive. I had heard they lifted the body off on the newer trucks, but I had never seen it. Good grief, that is insane. It's gotten to the point where the common man can't do his own wrenching.
I talked to a local Ford mechanic about this recently when I saw the same thing done to an '04 F-150. They claim that it Ford built their new trucks in a way that it only takes 30 minutes to pull the body off the frame. I guess they have quick disconnects on all the electronics so you just essentially unplug the cab, take out a few bolts, disconnect the steering, and lift up the body. The tranny is fly-by-wire, so there's no linkage to mess with.
According to the mechanic I talked to, they save 3 hours on a head gasket job by pulling the body off.
I've got a '02 Explorer and I can honelty say that I pray that I never need to change the plugs because I can't even see where they are. They've got the new motors shoe horned in so tight that pulling the body off is probabily the only way to do some of those jobs.
I have not done my 01 explorer (4.0 SOHC) yet, but I was told to remove the passenger side tire and take out the inner fender liner to get to the plugs on that side. Thats bad enough, but to pull the entire body? This is news to me. I guess I will have to go open the hood and look at something newer.
You can still open the hoods?
BTW: What transmission does your explorer have svoom? Some of the newer ones (newer than mine) do not have a transmission dipstick.
WOW! I am impressed and thankful for the technology and improvements of the newer vehicles compared to our trucks. But as a design engineer, it really blows my mind how a vehicle could be designed that needs the body removed to work on the engine! That's just nuts.
I worked as a mechanic for about 15 years at various GM dealerships and always swore that if I ever met one of the engineers I would bust him up side the head! The vehicles sure have come along way though and are engineering marvels, now I'd shake their hands (and then maybe clock them a good one)
My daily driver (company truck) is a 2005 F-150 extended cab, every time I open the hood I giggle a bit to myself and give thanks that now-a-days all I have to do is go to the dealer and say "here, you fix it".
It's not a huge stretch of the imagination to see that it would be easier to lift the bodies off to get to the engines. I worked with one guy who preferred taking the truck beds off to get to fuel tank sending units, he swore it was faster than dropping the tank (I thought he was nuts)
I have also heard that it is easier to take the cab off to replace the head gaskets on the new SD with the 6.0 PSD. Talk about a nice pay check after that. These manufacturer's just have to stuff the motor in underneath the dash. Good luck with yours PanelMan.
Brain_B,
Ooooooohhhhhhh....Don't even get me started on the transmission!!!!
I've got the 4.6 V8 with the "electronic overdrive" tranny. I'm not sure what the official model is but it's junk none the less. You are correct on the dip stick, or lack there of. The tranny's on the '02 and newer are all fly by wire and have no mechanical connectors to the rest of the vehicle. When you put the truck in gear, it's actually a servo doing it for you. Scary stuff. I'm convinced that there's a little old lady that lives in my tranny becuase there's a huge delay when you put it in gear and a huge delay between shifts. The tranny's are sealed (hence lack of dip stick) becuase any tiny amount of contamination causes major problems. I've complained to the Ford service department a dozen times and their standard answer to me is "that's just the way it is."
Brain_B,
Definately not the answer that i'm looking for.
YOu probly wont like this but that is exaclly why I perfer manual tranies. It is a shame they are rare any more.
Taking the body off once every 100,000 miles to change plugs, etc. seems pretty reasonable if it saves time and money. It's not like the old days where you have engine maintenance every 1,000 miles or so.
