Coolant Leak
Old Dec 6, 2005 | 04:54 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
Angry Coolant Leak
Hey Guys... Got Something That Been A Little Frustrating To Me.
A Few Months Or So Ago I Replaced My Waterpump. (about 50,000k).
Anyway The Change Out Was Easy Enough But After Warming It Up And Test Driving It There Was A Very Small Leak At The Thermocouple Housing. I Had Not Bought A Housing But The Flat O Ring Was New.
Took The Housing Back Off ....cleaned It Up Again And Used A Little Bit Of Permatex Form A Gasket And Re-installed The Housing. This Fixed It...for A While.
About A Month Later Got Tired Of The Little Bubble Leaks That Had Come Back.... Went Down To Dealership And Bought A New Housing And A New Flat O Ring. Cleaned It Up And Installed...fixed.. No Leaks.
Now Today...bout A Month Later... Leaking Again (wheater Is Colder But Not Much )
So We Have New Water Pump... New Thermocouple Housing ... New Flat O Ring.... Torqued Down Properly And Evenly. Leaking.
Any Ideas ??????? Thanks To All
Old Dec 6, 2005 | 05:12 PM
CAT_man_963's Avatar
CAT_man_963
Umm... do you mean Thermostat housing by any chance??
Old Dec 6, 2005 | 05:54 PM
4X4 IN REFUGIO
Yes... The Thermostat Housing... Where It Bolts On Top Of The Waterpump.
Leaking From Inbetween The Pump And Housing
Old Dec 6, 2005 | 05:57 PM
4X4 IN REFUGIO
Now I Know Why You Asked Me This Question Cat Man.
Just Reviewing My Post And I See That I Had Been Thermocouple Instead Of Thermostat!!!!!!!!!!!!!! Don't Know Why I Did That..
Old Dec 7, 2005 | 07:44 AM
4X4 IN REFUGIO
More Info.... After Engine Warms Up ..... No Leaking
Seems To Leak A Little After Engine Has Cooled Down
Any Ideas
Use Permatex ?
Maybe A New Flat O Ring ?
Change Thermostat ( Still Has Original ) ?
Radiater Sealant ( Not A Good Idea ) ?
Old Dec 7, 2005 | 08:26 AM
Kwikkordead's Avatar
Kwikkordead
Any Ideas
Use Permatex ?
No Permatex! That will anchor the o-ring in place and prevent it from following the expansion and contraction of the flange. Use a thin coating of silicone grease, like the stuff that plumbers use for lubing faucets. Don't goob it up or the hydraulic pressures generated between the flange and the o-ring will cut the o-ring in two. Been there done that. Just enough to make it look wet.
Suggest a slightly thicker o-ring if you can find it. I suspect something was not machined just right and it's not putting enough pressure on the o-ring to seal up good.
Yes get a new thermostat, can't hurt while it's apart again.
Avoid radiater sealant like the plague!
Old Dec 7, 2005 | 01:28 PM
skibender's Avatar
skibender
If replacing the thermostat, you might want to consider buying a 203 degree. When I did a search on replacing the waterpump on my truck, seemed like just about everyone recommended the hotter thermostat. Diesel's like to run hotter.
I agree with Kwik, the o'ring groove might be slightly large and not allowing a complete seal after the bolts are torqued down.
Old Dec 7, 2005 | 10:39 PM
4X4 IN REFUGIO
Thankyou Kwik And Skibender......
Think I Will Look For An O Ring That Is Slightly Thicker.
I'm Gueesing That Possibley The Waterpump That I Have Installed My Be Off A Little On The Machining Where The T-stat Sits In Causing It .... Well ...going To Try And Get A Thicker O Ring Instead Of A New Waterpump.
Thanks Guys.....i'll Let Yall Know.
