engine knocking
Old Dec 6, 2005 | 04:13 PM
BIG-COUNTRY's Avatar
BIG-COUNTRY
engine knocking
whenever i start my truck there is a knocking noise in the motor and it only does it for a little while then stops. could this be my engine valve? why does it do this?
Old Dec 6, 2005 | 07:32 PM
brandon9571's Avatar
brandon9571
By little while, do you mean 10 seconds? If so, your rod bearings are proabably getting a little worn. It just takes a while for the oil pressure to build up.
Old Dec 6, 2005 | 07:38 PM
BIG-COUNTRY
well it does it for about 4or5 seconds. it this somthing i need to get replaced soon?how much would it cost?
Old Dec 6, 2005 | 07:48 PM
brandon9571
The only way to fix it is do a complete overhaul. But I wouldn't worry too much about it unless it gets louder or longer. 4 -5 seconds really isn't that bad. An engine swap done by a good shop will cost $1500+
Old Dec 8, 2005 | 02:40 PM
imlikeojnow's Avatar
imlikeojnow
if your rod bearings are worn you dont have to do a complete over haul, you can replace the main bearing, and all. basically it is a bottom end rebuild. but if your cylinder walls are trashed you will have to get them bored out, and then do a rebuild. but if it was like mine and a little wear on the rod bearing, i replaced those when i did the oil pump, basically replaced everything i could get too while i had the egine up and the pan off. runs great now
ken
perryg114
Modular V10 (6.8l)
Apr 19, 2016 02:00 PM
PEG
1997 - 2003 F150
Nov 18, 2015 12:55 PM
RussB
6.7L Power Stroke Diesel
Nov 10, 2014 08:35 PM
trvctyrich
Dec 9, 2011 03:03 PM
Hanky
Electrical Systems/Wiring
Feb 10, 2001 12:49 PM
