Tachometer conversion for those without
Old Dec 6, 2005 | 09:33 AM
hydrology_joe's Avatar
hydrology_joe
Does anyone have a conversion table to determine the RPMs at different speeds in different gears? I have a 97 XLT 2wd 2.3L M5OD and it doesn't have a stock tach. I am just curious to know what RPMs I'm running.
Old Dec 6, 2005 | 10:21 AM
Rockledge's Avatar
Rockledge
I'm not aware of any tables like that myself, but I bet they exist somewhere.
Have you thought about changing out your stock speedo/instrument gauge cluster with another OEM one that has the tach? IIRC, they are plug and play on your '97...
Old Dec 6, 2005 | 06:26 PM
AlfredB1979's Avatar
AlfredB1979
A 95-97 factory tach cluster will work for you. More than likely cheaper and less work than an aftermarket version.
The only thing on the 95-later clusters I can't tell for sure is how to swap odo readings out. On the 94-earlier tach clusters, you just pop out the speedo center section and swap. The later ones call for being handly with a screwdriver or knowing a speedo shop in the neighborhood.
Old Dec 6, 2005 | 06:52 PM
ColonyPark's Avatar
ColonyPark
I was wondering this too. Why couldn't we just remove the Speedometer and Odometer from the old cluster and install it in the new one?
Old Dec 7, 2005 | 02:44 PM
shorty98371's Avatar
shorty98371
would this work on a 90 ranger?? (2.3L, M5OD)...?
Old Dec 7, 2005 | 09:31 PM
michigan66's Avatar
michigan66
Try: www.angelfire.com/fl/procrastination/rear.html
for a conversion table.
I have a cluster out of a 92 Explorer that I plan on putting in my 91 Ranger. The same swap should work on the 90 Ranger.
