aftermarket deck
Old Dec 27, 2005 | 03:27 PM
7sixf150's Avatar
7sixf150
well i got a new pioneer deck on boxing day. i took out my old radio. and yes there is the metal bracket everyone was talking about. so i understand i have to cut that. but i won't need to adjust the AC or anything as i sorta put it in and it fits. do i have to do anything after i cut that metal bracket off or can i just leave it and mount my cd player in? and does anyone know what all the wires are for. and can tell me so i do'nt have to play around to much. lol. thanks
Old Dec 27, 2005 | 03:39 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
when i installed a pioneer CD player in my 76 F-150 i used a stereo install kit(mainly for the plastic surround),first i cut the dash panel to fit...then i took the metal bracket out, and bent the lower half backwards as much as the heater/ac switch allowed, then i attached metal strips(with alot of holes in it) used for securing the back sides of stereos...reinstalled the bracket and dash panel....install the kit per instructions, slide in the stereo and attach to the metal straps from below...sounds like alot, but it only took me part of an afternoon to finish it....
Old Dec 27, 2005 | 04:32 PM
7sixf150's Avatar
7sixf150
i love your truck haha. did you go your rims from LMC truck?
Old Dec 27, 2005 | 06:06 PM
1975Ford's Avatar
1975Ford
Mark outs the stock radio mounting bracket / AC & heater control mounting bracket (stock bracket) with retangular mounting metal bracket from CD/MP3 player.To fabricate a bracket for the radio, you will need some type of sturdy metal. Use the rectangular metal bracket for the CD/MP3 player as a template to mark up this sturdy metal then usiing a table vice to hold metal as it will make handling and cutting the stock bracket and sturdy metal more of a breeze.
I used a jig saw with a metal cutting blade to cut up mark outs.
I then used a mig welder to weld sturdy metal to the stock bracket.
NOTE: Verify your mark outs proir to cutting, Cut out should not be to high or low.
My Radio and speakers install took 3/4 of day, and was well worth the time.
Old Dec 27, 2005 | 06:32 PM
SwOkcOffRoader
Thanks man...... actually my friend bought the rims and tires from 4wheel parts for his Geo tracker!! he sold them to me for $350 tires and all (on payments!!)....he only had 7 miles on them when i bought them!! i keep getting told i wasted a good set of offroad rims, since they are meant to have big offroad rubber on them....oh well, they look sharp where they are at!!
Old Dec 28, 2005 | 12:36 AM
7sixf150's Avatar
7sixf150
hey can you tell me which colour wires go to which wires on the deck? they should be the same since we both got pioneer decks and 76 trucks right? if you could that would save me a ****load of time. lol thanks
Old Dec 28, 2005 | 05:08 AM
SwOkcOffRoader
grey, green, brown, and purple are usually speaker wires...you will have to go by trial and error to find out which speaker is which....red is power, orange/yellow is memory power, blue is power antenna.......
Old Dec 28, 2005 | 09:45 AM
trinogt's Avatar
trinogt
After I cut my dash opening to fit the new style DIN mount deck, I used the supplied trim plate to fit over the factory trim panel.
I also kept the factory radio rear support bracket, and it perfectly fit the new stereo which comes with a threaded hole or a stud in the rear in just the right location. Remove ashtray for this procedure. You can feel the back of the bracket by hand, and thread on the new nut by feel and then get a wrench on there (I think the supplied nut was 10mm)
This bracket keeps the stereo from bouncing around, and secures it in place instead of relying on just the front mount.
Mark
Old Dec 28, 2005 | 01:17 PM
7sixf150's Avatar
7sixf150
do i connect my yellow wire off my deck straight to the battery? it says wire to a terminal that has power all the time.
Old Dec 28, 2005 | 03:12 PM
1975Ford's Avatar
1975Ford
The main yellow wire can go direct to any direct hot wire on the fuse box. Radio Shack sells a connector that goes in back of the fuse and the fuse slip onto this connector and then a wire connector will complete this connection.
Old Dec 28, 2005 | 03:18 PM
7sixf150's Avatar
7sixf150
so i shouldn't wrap it around a fuse and shove it in there? lol
Old Dec 28, 2005 | 03:33 PM
trinogt's Avatar
trinogt
Haha, been running my tach that way for a very long time, but don't tell anyone! Lol.
If you run an amp, you can run a heavy gauge wire (6 or larger) from the battery, to a power distribution block, then split from there to the deck for your continuous (memory) wire. Run an inline fuse on that heavy wire, like a 40 amp, or close to what your amp requires, BEFORE the block.
Mark
Old Dec 28, 2005 | 03:39 PM
  #28
7sixf150's Avatar
7sixf150
Mark
loli ran my tach like that in my mazda(rip).
i do have an amp. a 1000w. but i don't think i'll be hooking it up for a little while.
Old Dec 28, 2005 | 03:42 PM
  #29
1975Ford's Avatar
1975Ford
I ran my hot wire wrapped that way, lol, it seems like the wire would come loose sometimes.
Old Dec 28, 2005 | 03:47 PM
  #30
7sixf150's Avatar
7sixf150
does my 76 have one front speaker? or are there 2?
