My heater doesn't work. Last time I used it it wouldn't switch from heat to cold. Then it switched and now it won't switch from cold to hot. I have plenty of antifreeze any suggestions?
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Hey fled,
Sorry for the dealy in your getting any response.
I've been out quite a bit the last few weeks.
Anyways, did you get your problem resolved?
Sounds like the problem might be in the vacuum switching behind the panel. I believe the hot/cold blend door is vacuum actuated as is the vent/defrost/floor ducting.
