Power lock mystery
Old Dec 5, 2005 | 02:59 PM
jcp123's Avatar
jcp123
Power lock mystery
I have a '92 Bronco, and 4 of the wires on the passenger side power lock pigtail (part right behind the door panel that the switches themselves plug into) have come loose. They are the wires on connectors # 1 (pink/green),2 (pink/orange),3 (black/white hot wire),5 (?).
What I can't figure out is that on #5, the wire that I think is supposed to connect to it is a lavender/yellow or pink/yellow wire which I have not found on any wiring diagrams. Should I sauder it back on there anyway? There's really no other place for it to go and every other wire on there corresponds to where it should be anyway...
Old Dec 5, 2005 | 05:47 PM
1975Ford's Avatar
1975Ford
Try matching the wiring on switch on the opposite switch (driver side).
Old Dec 6, 2005 | 06:08 AM
subford's Avatar
subford
RIGHT DOOR
1 = PK/LG (UNLOCK) from left door
2 = PK/O (UNLOCK) to locks
3 = BK/W (POWER) from 20A CB
4 = PK/BK (LOCK) to locks
5 = PK/Y (LOCK) from left door
DO NOT LOOK AT LEFT DOOR !!!
It is not even close to the wiring of the other door.
Old May 13, 2007 | 06:45 PM
Sgt Wonderful's Avatar
Sgt Wonderful
Left door lock
Whats the left door like. Right door very helpful.
Old May 14, 2007 | 07:30 AM
subford's Avatar
subford
What year would you like the diagram from and what model?
Old May 14, 2007 | 10:48 AM
Sgt Wonderful
power locks
80-86 ford P/U
going to install in a 79 P/U
Old May 14, 2007 | 12:26 PM
subford's Avatar
subford
80-86 ford P/U
The diagram below should be right but some of the wire colors may be off.
The 627 BK/O may be circuit 119 PK/Y D and so on.
Here is the diagram.
http://i54.photobucket.com/albums/g9...ndow/PG103.jpg
Old May 14, 2007 | 04:31 PM
Sgt Wonderful
Power Locks
That diagram shows a switch with 5 poles, all my switches have 6 poles.
Old May 15, 2007 | 12:09 AM
subford's Avatar
subford
The one I posted above was for an 1988 F series.
Here is one for an 1983 F Series:
http://i54.photobucket.com/albums/g9...dow/83pg74.jpg
Old May 15, 2007 | 10:59 AM
Sgt Wonderful
Power Locks
Thanks, that looks like the correct one. And they told me it was a 80-86. Live and learn.
Old May 15, 2007 | 02:40 PM
Sgt Wonderful
Power Locks
Thanks for your help SubFord, it now works as it should.
