pinion seal replacement
Old Dec 5, 2005 | 09:55 AM
two-dogs66's Avatar
two-dogs66
Question pinion seal replacement
I am just before going into the garage and doing exploratory surgery on my 2000 F-550 rear-end-there is a major leak (90w) on the front of the diff. Iam not sure as to how the pinion seal is removed (I'll do it the hard way anyway) I cannot locate any site that has pictures of my diff. so I dont know how much will need to be removed---If you have ever replaced a pinion seal---PLEASE tell me about it. Maybe I'll have one more cup of coffee before I start. Two-dogs66
Old Dec 6, 2005 | 03:09 PM
bob arrington's Avatar
bob arrington
the best suggestion I can make is to do a search for "pinion seal" in this forrum , there is a whole lot of info in here, bob
Old Dec 6, 2005 | 06:20 PM
rclarke's Avatar
rclarke
Consider having a shop do it unless you are prepared to handle 500 ft/lbs on the pinion nut.
Old Dec 8, 2005 | 10:46 PM
two-dogs66's Avatar
two-dogs66
you sir are absolutely correct at least 500ftlbs as I found out the hard way, but I got er done and because of the nut in Question I will allways remember the experience----------two-dogs66
BrianQ
Large Truck
Jul 24, 2016 10:36 AM
nvrsadi
May 17, 2016 05:19 PM
John Boyd
Dec 30, 2012 12:10 PM
stephen.south
Feb 28, 2012 12:53 AM
