.............I will be using my 99 PSD strictly for towing !! I have decided to go with a 3.5 inch downpipe into a full 4 inch system with a Walker BTM . Will this install puncture or screwup my heatshield . Ford installed the heatshield for a very good reason and I DON'T want the integrity breeched . I'm looking for input from those who have either installed their system Themselves or "had" their system installed . Thanks , s.kuteman
it will be hard to stuff a walker BTM into the system, as the inlet and outlet of the BTM is designed for 3.5'' piping. although, most exhaust systems have a muffler with a "straight through" design, which is very similar to the BTM. i have a 4'' system, and i did not have to move the heat shield, nor is it in the way of anything. i have a MBRP system, and it is superior in design/bends. a 4'' downpipe will fit with no rubbing issues whatsoever, i could easily fit a 5'' downpipe and still have room, because there is about an inch radius around the pipe before it hits anything.
since you are towing, i would seriously consider the 4'' downpipe. the only real advantages of a smaller downpipe is low-rpm power. since you are towing, i believe most of your rpm's will be over 1750. i have a 4'' turbo back system, and i routinely see 1000-1400 cruising speed, say coming into a 35mph zone, if i dont take OD off, it will run about 1100 rpm, and it still has ALOT of power for that speed. plus the smaller downpipe keeps heat. a larger one will reduce EGT's, and that adds longevity.
You can ceramic coat the down pipe, It will hold the heat in the pipe and eliminate the use of heat shields. I do ceramic coating and it works great on snowmobile pipes.
i was just looking on ebay, and it looks to me like i am going to wrap my downpipe and at least my hot-side intercooler pipe, in the near future. keeps under hood temps down! if only i could get to my up-pipes easily!
