Sponsored by: Real Truck
Telescopic Mirrors/Replacing
Old Dec 3, 2005 | 07:33 PM
Gene in Alaska's Avatar
Gene in Alaska
I have a 2003 Ford F-250 crew cab. Someone broke the amber lens on the driver's side, heated telescopic mirror while it was at a shopping center. I thought I could just get an amber insert but ended up having to get the entire front portion of the mirror...After looking at the replacement it looked pretty much straight forward to pop it off and replace it. Wrong. Didn't cooperate! Can anyone out there advise how to replace this. It's got to be a simple process...
Thanks,
Gene in Alaska
Old Dec 4, 2005 | 09:29 PM
Miescha's Avatar
Miescha
I take it you're just replacing the black plastic - not the mirrors or arms - is that right?
If so, I can't help but I'm sure someone else can. If you are replacing the entire mirror housing, I've done that several times on my '99 350. The telescoping tow mirrors are held on by three bolts that are accessible from behind the plastic triangle cover on the inside of the doors.
Old Dec 5, 2005 | 09:36 AM
DirtyDieselPhil's Avatar
DirtyDieselPhil
Hi Gene - I just posted this same question. Here's the thread link:
https://www.ford-trucks.com/forums/s...d.php?t=434698
And another link, with pictures about the install:
http://www.eurekaboy.com/f250/newmirrors.htm. It has to do with upgrade from the sport mirrors, but the info is very helpful. Link at the bottom of the page for installation instructions, and the door panel removal instructions.
I ended up ordering a new assembly (clamshell and mirror) from parts.com. The part no I used (driver's side, power, no heat or lights) is 3C3Z-17683DAA
Good luck
Phil
Old Dec 5, 2005 | 11:06 AM
Gene in Alaska
Thanks for your information...I am only replacing the black plastic that contains the amber lens...
Old Dec 5, 2005 | 11:11 AM
Gene in Alaska
Phil,
Thanks a lot for your input...The site was an excellent one for removing or replacing the mirror...All I need to do is replace the black plastic forward portion that contains the amber lens...
Gene
