Modular V10 (6.8l)
Need some Help!!!! with mechanical question!
Old Dec 3, 2005 | 07:26 PM
bigjake0524's Avatar
bigjake0524
Exclamation Need some Help!!!! with mechanical question!
Ok the problem was a very sudden change. I was getting 12.9mpg and it dropped in a matter of days to 9.5mpg. The only change was new tires replaced with the same size; I did however have the new ones siped. And at the same time I put new wheel bearing assembelies on at the same time so technically rolling resistance should have been lowered because the old ones were trash. Any help would be apprciated. Oh I replaced the plugs and boots about 40k ago. Could it be Mass Air, O2? No codes have been thrown. Any help would be greatly appreciated.
Old Dec 3, 2005 | 07:54 PM
mdpopo59's Avatar
mdpopo59
Sounds like a drag issue. New bearings can be stiff and take time to break in. New siped tires will also have more rolling resistance than older worn tires. Also, different brands of tires have differences in rolling resistance, you may want to up your air pressure.
When I switched from Michellin MXV4's to BFG Traction T/A's on my wife's car the mileage dropped 2mpg.
Old Dec 3, 2005 | 08:08 PM
Antelope V-10's Avatar
Antelope V-10
My last fill up was 8.97mpg's, down from 10. I think it might be the winter blend of fuel.
Old Dec 3, 2005 | 08:25 PM
Wrenchtraveller's Avatar
Wrenchtraveller
I think you got a bad tank of fuel. Getting tires siped is supposed to increase mileage according to a site I found on this subject. I was all set to get this done to my Contis until I discovered there're not as bad as many people make them sound. There are not an A/T tire , more of an A/S tire but I got my money back from my dealer over that and I am fairly satisfied with them now.
To check your wheel bearings for drag, put your truck in neutral on a very slight grade. If the truck does not roll, you may have a problem. Mine rolls very easy on my driveway which has a very mild slope.
Old Dec 3, 2005 | 08:30 PM
ford390gashog's Avatar
ford390gashog
could be winter gas tons of oxygen.
Old Dec 3, 2005 | 09:29 PM
captchas's Avatar
captchas
Guest
i have the same problem here in new jersey. the garbage winterized fuel is now coming in. when i smelled the difference my milage dropped.
Old Dec 4, 2005 | 01:01 AM
bigjake0524
Thanks for the responses. I will check some things out and see if it helps! Maybe it is just the 184000 on the v10 catchin up.. HAHA....
