Drip from back right frame?
Old Dec 3, 2005 | 06:10 PM
SuperDave1968's Avatar
SuperDave1968
I just bought a 2005 Expedition, about 1 year old. There is a wet spot under the rear right side fo the vehicle, just behind the muffler. The snow seems to melt on the driveway when it hits the spot left last night. The liquid is clear and does not have any noticeable fumes or odor. I looked under the vehicle this afternoon and it appears the frame is wet just above where the wet spot is. Any ideas?, or has anyone else experience this and may know what it is? Thanks for any input.
SuperDave
Old Dec 3, 2005 | 06:19 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Dec 3, 2005 | 07:30 PM
Luzer27's Avatar
Luzer27
My guess is one of several things. There are coolant lines that run down the right side and cross over for the rear heater/AC, I doubt these are leaking because it would be green or orange, next guess is trapped water or maybe even ice, this could be bad due to rust. Check seems and drain holes in doors and rocker panels. Lastly it could be condensation from the exhaust system, the muffler and resonator both have a small hole to let water drain and prevent corrosion in the items. Let us know what you find.
Dave
Old Dec 3, 2005 | 07:51 PM
ford390gashog's Avatar
ford390gashog
luzer,
there is a much more obvious cause. the a/c condensor has a drain tube there for water. if you run the defrost or a/c it will drain from there.
Old Dec 3, 2005 | 11:32 PM
broncoholic's Avatar
broncoholic
I'm with gashog, it's the rear ac condensor.
Old Dec 4, 2005 | 03:36 PM
AwesomeBullet's Avatar
AwesomeBullet
[QUOTE=Luzer27because it would be green or orange
Dave[/QUOTE]
The 05's use the standard Motorcraft "yellow" antifreeze....
Old Dec 4, 2005 | 08:53 PM
ford390gashog
most ford cars 2001 and up use motorcraft yellow.
Old Dec 4, 2005 | 11:41 PM
Luzer27's Avatar
Luzer27
Well I am glad I used the word "guess". Is the AC on the 05's on the rear right as mentioned in the first post?
Dave
Old Dec 5, 2005 | 07:43 AM
shov76's Avatar
shov76
Yes it is on the right back side.
Old Dec 5, 2005 | 10:09 AM
Luzer27's Avatar
Luzer27
OK, I know the AC runs on these trucks almost all the time to aid in humidity, but the idea of the evaporator actually forming condensate in cold weather is unlikely (look in your freezer), broncholoic mentioned the condensor but this is inforont of the radiator, I think he meant evaporator. Since the heater core for the rear is in this area I still think he might want to look into the fact that it is leaking. It would be unlikely in cold weather for him to be running ac on full blast, most likely full heat to warm the truck up, he said there was snow on the ground. If this was the case the hot air from the heater core would dry and carry the condensate from the evaporator. details.
Dave
Old Dec 5, 2005 | 07:53 PM
AwesomeBullet
It is also a good indicator the heater core is leaking when he mentioned that "The snow seems to melt on the driveway when it hits the spot left last night"...
