vibration 79 4x4
Old Jan 26, 2002 | 10:34 PM
Kenworth's Avatar
Kenworth
vibration 79 4x4
Old Jan 31, 2002 | 10:49 AM
mike79f150's Avatar
mike79f150
vibration 79 4x4
I recently bought this truck, it has a 4 inch lift, it drives fine in the two wheel mode. However when it is put into four wheel drive I get a vibration about 12-15 mph and can't find a problem. I've checked the hubs, drive shaft for in phase, all the u-joints and still can't come up with the answer if you can help me I'd appreicate it, THANKS 1979 f150 short box
Old Jan 31, 2002 | 02:49 PM
DantheMan's Avatar
DantheMan
vibration 79 4x4
-I'd say maybe your front pinion angle is too steep because of the lift. I'd have it checked. Also take another look at the U-joints again, -bad ones don't always have to look bad.
Old Jan 31, 2002 | 07:25 PM
mike79f150's Avatar
mike79f150
vibration 79 4x4
What should the pinion angle be at the front axle with a 4" lift? How do I have it checked? Is a double cardan cv joint needed? If I must replace the 'c' bushings,what degree do I install? 2,4,or 7 degree? Vibration is most noticed at 12 MPH,even if the truck is running in gear on jacks(tires removed).Could a front axle u-joint cause a significant vibration,yet feel tight (without removing it)?
