Great site! I'm still learning my way around! I have a 2002 F350 4x4 x-cab diesel. I'm probably going to ask alot of advice around here so please bare with me! So far I need advice on what's best on tires for dual wheel trucks? I've always ran Michelin LTX M/S. A little $$.. Everyone always have said to run these because of tread life. I have 76000mi on this truck and I'm on set 3. I do alot of towing equipment and was wanting to know is it worth the extra $$ for Michelin or just save $$ and go to a B.F. Goodrich tire?? I hope I post this in the right place... If not, please forgive me!!! I'll do better!!!!
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page. JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
Three sets in 75k? That makes my 2 sets of Goodyears in 87k (6 years) look good. I still wasn't satisfied though.
I switched to Toyo Open Country A/T's. They balance better (tighter production tolerances), have excellent traction for an A/T, are Load Range E, and cost 20% less than the Goodyears.
In your case I would avoid the BFG's. They ride hard due to the formula and traction in snow & mud is horrible because the tread blocks don't "clear". It's an old design using smaller blocks whereas the Goodyear ATS and the Toyo's use larger tread blocks and sipe them.
