Brake Conversion help
Old Dec 2, 2005 | 03:39 PM
DGMFORD's Avatar
DGMFORD
Question Brake Conversion help
I'm currently doing a frame off restore on my 1955 F100, after removing the stock clutch and brake pedal, I realized that there is something missing. I'm going back with a frame mounted master and booster, using the stock brake pedal. If I remove the stock clutch pedal, there is nothing to hold the brake pedal in place, is there a kit I'm missing? I'm using a master/booster kit from CPP, I did notice that they sell a kit if your using your stock clutch pedal, but I don't seem to find anything else. I did notice that I can remove the old clutch arm from the rod however, still don't understand what keeps the stock brake pedal in place. thanks for you help.
Old Dec 2, 2005 | 04:37 PM
DGMFORD's Avatar
DGMFORD
Never mind, it helps when you open the box and look at all the parts inside the box. There is a new shaft that comes with the brake booster kit. thanks again.
Old Dec 2, 2005 | 04:43 PM
53fatfndr's Avatar
53fatfndr
The best questions asked, are the ones that answer themselves
Old Dec 2, 2005 | 05:16 PM
havi's Avatar
havi
I'll have the Roast Duck
without having seen a 55 up close inside, do the pedals hang or do they come up through the floor like on my 48? And would they swap over?
Old Dec 2, 2005 | 05:55 PM
docholiday72tx's Avatar
docholiday72tx
I don't know if 48 and 55 interchange, but I do know the pedals in my 55 come through the floor. Does any one know the best donor vehicle for swinging pedals that would include power breaks and a hydraulic clutch?
Doc
Old Dec 2, 2005 | 06:03 PM
AXracer's Avatar
AXracer
I used the swinging pedals PBMC and CMC from a 93 Camaro, mostly because it's where my T56 came from. Had to modify the mount a bit to widen the spread between the pedals to straddle the steering column, but otherwise it fit well, see my gallery.
