Engine Block Heater
Old Dec 1, 2005 | 10:27 PM
FFCross's Avatar
FFCross
Engine Block Heater
hey everyone, it is COLD here in Iowa. What is the best way to install an engine block heater in my 70 sport custom 360? I want to stay away from the heated dipsticks of the world, and do it the right way. Happy Holidays!
Old Dec 2, 2005 | 12:26 AM
ford390gashog's Avatar
ford390gashog
well on a v-8 you need 2 for best results. remove the front freeze plug on both sides and install 2 heaters. they run 25.00 www.summitracing.com
Old Dec 3, 2005 | 08:15 AM
jor's Avatar
jor
Or you can get the type that installs in-line in the heater hose. When we lived in North Dakota (brrrrr) I had one of those in my 67 F-100 and the freeze plug type in my Toyota. Everybody up there plugs in their cars and a lot of the motels have outlets where you park the car.
jor
Old Dec 3, 2005 | 04:09 PM
Dave Severson's Avatar
Dave Severson
Yup, what Ford 390 said. Same method I've used for years on all my Fords. I'm in South Dakota, been known to get a bit chilly around here, too.
Old Dec 3, 2005 | 07:43 PM
baitmaster's Avatar
baitmaster
I went thru a lot of winters in Wis, and I used a upper rad hose heater on mine. Worked great and easy to install, just cut the hose and add two clamps.
Old Dec 4, 2005 | 02:22 PM
FEmtnmax's Avatar
FEmtnmax
I use the in-block heaters. The ones in the hoses eventually bake the hose. Just be real careful when tightening the center nut on the block heater. Make sure the heater unit is fully seated against the block and slowly tighten the center nut. It is easy to strip out.
Old Dec 4, 2005 | 04:01 PM
bob arrington's Avatar
bob arrington
up here in alaska , we have found that the best block heater is the magnetic oil pan heater . you make sure that your antifreeze is correct, and the oil pan heater heats both the oil and the antifreeze at the same time. Its easier to install also. you do need to put gasket sealer arround the edges to insure that it doesnt get blown off while driving down the road, my 2cs,bob
