Awd---
Old Dec 1, 2005 | 09:36 PM
Notpilbrisk's Avatar
Notpilbrisk
Question Awd---
ANy 1 no if you can disable teh awd in 99 expeds i hear its pretty pointless and would prob land you in a ditch. Any feed back would be great. thx Gerry
Old Dec 1, 2005 | 09:38 PM
Notpilbrisk
A4WD that is my Fault.
Old Dec 1, 2005 | 09:46 PM
topfisherman's Avatar
topfisherman
If I remember right there is a fuse in the engine bay, and if you pull it, it disables the A4WD. Although, I can't remember which one it was exactly.
Old Dec 2, 2005 | 05:10 AM
Notpilbrisk
By pulling this fuse would it disconnect any other features in the truck???
Old Dec 2, 2005 | 09:21 AM
Jimmygunz3's Avatar
Jimmygunz3
Pull Out The #104 Fuse Fron The Fuse Panel Under The Hood, It Is Only For The 4wd Clutch And Transfercase Motor. The Only Thing Is That When You Connect It Back Your 4wd Will Not Work. I Actually Just Took Care Of This Problem This Morning. You Have To Disconnect Your Battery For 30 Min Or More To Reset The Computers, And Then It Will Be Fine. Hope This Helps You.
Old Dec 2, 2005 | 09:57 AM
happycamper116's Avatar
happycamper116
Thats strange, I had mine out all summer til fall I was in the mud had to jump out put the fuse back in and the 4WD worked, did not have to disconnect the battery. mine is a 2000 Eddie Bauer. would that make any difference. Brian
Old Dec 3, 2005 | 03:08 AM
quick35th's Avatar
quick35th
Did you guys notice any increases in fuel economie with the AWD dissabled?
Shane
Old Dec 3, 2005 | 07:17 AM
happycamper116
Shane, I really never noticed much difference in fuel mileage but strange enough, I really noticed a difference in the way it handled. I didn't feel the wondering I usually feel with it. Like usually cruising down the highway I feel like I am always correcting the steering, but with the 4awd disabled I could see a noticable difference. Also, we pull our 5800lb travel trailer with it and it just seems to have more torq disabled. Maybe it is in my head, but either way can't wait til spring so wify will let me disable it again. Brian
Old Dec 3, 2005 | 11:56 AM
Notpilbrisk
so if you disable a4wd u cannot use 4wd high or low??? or do u have to reinstall the the fuse for the 4wd high and ow to work...??Gerry
Old Dec 3, 2005 | 12:05 PM
happycamper116
On mine, if the fuse is out, I cannot use 4wh or 4wL.
Old Dec 3, 2005 | 03:24 PM
Jimmygunz3's Avatar
Jimmygunz3
If you poll the fuse out you cannot use 4H or 4L, The fuel consumption was the same
Old Dec 3, 2005 | 04:50 PM
WillieWildcat's Avatar
WillieWildcat
Just leave it in A4WD and then you don't have to worry about any unforeseen circumstances. Your MPG won't suffer and that is what the truck was designed for.
Old Dec 4, 2005 | 03:30 PM
quick35th's Avatar
quick35th
I wander why the 97/98 expys that have 4X4 but also a 2wd option on the switch are rated to get better gas milage than the AWD models? Maybe it was a dealer miss print but when I was shopping for my expy I was looking at a '98 5.4L expy that on the window sticker said it got something like 15mpg city and close to 20 on the highway.
Shane
Old Dec 6, 2005 | 01:09 AM
ZUGtastic!!!'s Avatar
ZUGtastic!!!
Shane
only powering 2 wheels will give you better gas mileage than powering 4 wheels.
Also from my understanding if you drive in A4WD, you still only power 2 wheels, unless you lose traction in the rear, then it will power the front wheels. (hince Automatic 4WD)
