Engine block heater cord
Old Nov 13, 2012 | 02:53 PM
barnacle Bob's Avatar
barnacle Bob
Froim what i can tell, International sells the ZeroStart brand. It looks like a pretty solid cord and connector. Ford may be selling mounting hardware and the name. I will install it today.
Old Nov 13, 2012 | 03:14 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Yes the International cord is ok to use..... don't know if it's the EXACT same or not! Really doesn't matter.
Old Nov 13, 2012 | 03:33 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here is the Kats catalog, first one in the list:
Catalog
Page 13 for 6.0L and page 44 for the VT365 which also shows the Cordset for replacement.
Block heater part # incase they need replaced-----30513
Replacement cord part# 28216 (Cordset: 120V)
A quick look on-line: $13.68
Amazon.com: Kat's 28216 6' Replacement Cord: Automotive Amazon.com: Kat's 28216 6' Replacement Cord: Automotive
Contact Kats for confirmation of parts:
Contact
Old Nov 13, 2012 | 08:06 PM
Abram's Avatar
Abram
if I buy this after market cord (through amazon)It means that I have to get under each time and make a direct plug....and then again take it out (unplug the whole cord) to get going?...is there antyhthing thats is permanent (fixed)with a nice plug/in end....I'm thinking OEM maybe? how do the OEM's look like. Thanks.
Old Nov 13, 2012 | 09:44 PM
amdriven2liv
It is a 6' cord. Once it's plugged in to the heater, run the cord where ever. Most run it right up front behind the bumper. Just like stock. Look at the photo, you can see the 2 ends.
The OEM from Ford will, or, should come with zip ties and push pins and the cover over the cord. That is the reason, or one reason, they are more costly than aftermarket cords.
At least, that is what I have seen in research.
Old Nov 13, 2012 | 09:46 PM
barnacle Bob
they oem's are the same as the zerostart. there is a retainer screw that tightens down over the connector to secure it to the actual heater . Then on the opposite side, you have the male plug end that connects to your extension cord. oem or aftermarket, you will need to just plug in the extension cord placed just under the grill or fenderwell. where ever you decide to afix the cord to the frame.
Old Nov 15, 2012 | 06:36 PM
vagunter's Avatar
vagunter
EBAY or Amazon 17.00
Old Nov 16, 2012 | 06:54 PM
Abram's Avatar
Abram
OEM block heater cord
bought the cord today OEM...hopefully no more cold stars. 121 bones plus tax.
...so most of you say about three hrs.? what happens if you leave it plugged in all night...8 to 10 hrs persay. Thanks.
Old Nov 16, 2012 | 07:03 PM
amdriven2liv
Mine starting at about 39* and 9 hours last night for a test ended up at 125* (F)
But it depends on the outside temps!!!
Old Nov 16, 2012 | 07:19 PM
Abram's Avatar
Abram
right...outside temps...good , good point there. Here will be around mid 40's this coming week...so about 3 hrs shod be good you think?
this is the cord. Havent installed it yet. Should be easy with the handed instructions.
Old Nov 16, 2012 | 07:40 PM
Yahiko's Avatar
Yahiko
Looks like it comes with a how 2.
I have left mine plugged in over night and was
nice and toasty warm when I went out to start.
I was only 30F that night. I don't recall the coolant temp.
Sean
Old Nov 22, 2012 | 01:12 PM
Abram's Avatar
Abram
dealer wants to charge 184 bones to install this cord...is there anything special to this install? i'm just wondering. I m fixing to install it myself later on today is there anything I shoud/do know before I do it?...
Old Nov 22, 2012 | 01:31 PM
  #28
davbeisner's Avatar
davbeisner
Really easy install... Run the cord through from the front to the back. Easiest way to see is get on your back under the truck on passenger side. Feet towards the front bumper. Head back even with the transmission. Push yourself up on an elbow and look above the starter. You can easily and clearly see the plug. Push it in and you're done.
My dealer wanted $125 just for the cord, so I picked up an aftermarket cord with the same plug from carquest for $17. It's too short to reach the front bumper, so I mounted it below the passenger side door. I think I'm gonna attach an extension though, and move it, cause after driving through mud and snow I have to chip ice off the plug every night.
My aftermarket cord appears to be working well... I couldn't get the locking ring to screw on, and was afraid it would fall off all the time, but its held firm for about a month now.
I leave mine plugged all night and typically see temps around 125 in the morning. Ambient temps in the teens at night.
Old Nov 22, 2012 | 07:04 PM
  #29
vagunter's Avatar
vagunter
The aftermarket cord works like a champ and plugs into my extension cord to the house at the front bumper. lot of people permantly mounted it by wiring in a receptacle attached to the front bumper. looks really good
Old Nov 22, 2012 | 07:29 PM
  #30
Mars57's Avatar
Mars57
Sean
They say you only need 4 hours to bring your coolent temp up to the proper temp for starting. What you should do is get a timer and set it for 3am so you can start your truck at 7am. Any longer you are just wasting electricity. Of course if you need your vehicle in an emergency, it may not start. You need to decide, plugged in all night or on a timer.
