04 F150 3rd stop lamp doesn't work
Old Dec 1, 2005 | 02:31 PM
f150ita's Avatar
f150ita
I'm Italian F150 owner. In my truck doesn't work 3rd stop lamp. This is the central stop lamp. On the roof. I am motorcraft service registered user and after some test, conclusion is that I need to repair circuit 511 LG. Do everyone know where is this cicuit and which how it work. Many thanks for your help. Sorry for my bad english.
Old Dec 2, 2005 | 05:14 AM
Franklin2's Avatar
Franklin2
The third brakelight is driven directly from the brake pedal switch. So if the lower rear brakelights work, then the brake switch is ok, and you are probably correct, you might have a wiring problem or a socket/bulb problem.
Check to see where the wiring leads go. On my older truck, they run down the rear of the cab, and come out behind the driver's side seat in the floor. They then run under the door sill rocker panel cover on the driver's side. This is a very good place for wires to get damaged.
