Brakes sticking?
Old Dec 1, 2005 | 10:23 AM
closer9's Avatar
closer9
Brakes sticking?
I took my truck out for a little drive around town last night. Probably 5 or 6 easy stop light miles, then came home left it running while I went through the house to open the garage door (don't have an opener in the truck). When I pulled it in the truck just felt sluggish. After I shut it off I noticed the bumper was still in the way of the door, so rather than get back in I just put in N, and pushed it, but it took all I had to move it.
Came back out this morning as I was leaving for work, and just out of curiosity pushed it forward, and it rolled very easily... (BTW, I don't drive it daily)
I know it needs new wheel cylinders, and while I'm in there I'll replace the shoes and clean things up. The park brake cables stick, so I don't use it right now. Gotta get them off, and cleaned up.
I'm just curious what could cause the brakes to stick like this, then release during the night. Do I just need to clean things good while I'm in there, or is there something about these trucks I'm not aware of that needs to be addressed...
edit: BTW, my truck is a '75 F100 2WD, 390 auto, reg cab, SWB...
Old Dec 1, 2005 | 12:53 PM
Mil1ion's Avatar
Mil1ion
Corrosion from sitting can cause this.
Does the truck ever sit for weeks at a time ?
Old Dec 1, 2005 | 02:08 PM
closer9's Avatar
closer9
I've only had it for 2 weeks or so, but before that it sat for several months.
So, my best bet is probably just to clean things good, when I swap cylinders/shoes? Just wasn't sure if there was some problem unique to these trucks. This is my first Ford this old...
Old Dec 1, 2005 | 02:43 PM
derherr65's Avatar
derherr65
Flush the brake system. Sticking only when hot is an indication that there is water in the brake fluid. The water boils and creates steam pressure. It's not a lot, just enough to add a little drag. Seems to affect drums more than disc.
Old Dec 1, 2005 | 04:56 PM
closer9's Avatar
closer9
Well, I gott put new cylinders on anyway, so... will do.
billbot
May 11, 2012 01:36 AM
Mother_Love
1978 - 1996 Big Bronco
Jun 26, 2011 07:28 PM
Kim's Hipster
Mar 23, 2011 03:46 PM
RyanP0342
1997 - 2003 F150
Jan 27, 2010 10:39 PM
mountainar15
2004 - 2008 F150
Jul 6, 2004 01:36 AM
