Checking Gears (Having Problems)
Old Nov 30, 2005 | 05:06 PM
BigBody's Avatar
BigBody
Well, I have a 77 f-150 and am trying to figure out what gear ratio I have.
I jacked up the rear, had the truck in neutral, and spun the tire and the driveshaft only turned 1.5 maybe 2 times at most. I tried this numerous tiems and it always came out the same.
I know the gearing couldn't possibly be that high, so any ideas? It doesn't turn very good with the tire, any chance the rear end could be going bad? The truck has been ran pretty hard by previous owners. In fact, one owner let the breather tube come off and let it leak fluid so it could be low on that. I replaced the breather tube.
If you guys think the rear could be going out, what would be best way to go about getting another? I'd like to get 4.10's front and rear but money is tight. Find a new 4.10 3rd member for rear already set up then find a new dana 44 front with 4.10s in decent shape. All brakes on the 2 axles are good so I could use them for parts.
LMK.
Thanks,
Kyle
Old Nov 30, 2005 | 05:14 PM
Mil1ion's Avatar
Mil1ion
The way you did it ,it won't work.
Did you have both wheels off the ground ?
I assume 4x4.
It should be at last 3.00:1
What does the rating plate say the axle is?
No buck tag on the diff ?
Turning one wheel 10 revs is a closer way to solve it.
Some say you turn the wheel 2 revs to get the ratio.
Do a search for " determining axle ratio "
Old Nov 30, 2005 | 06:33 PM
User 71024's Avatar
User 71024
You have to turn both wheels 1 revolution and count the drive shaft turns.
Old Nov 30, 2005 | 10:27 PM
BigBody's Avatar
BigBody
I did not see any plate or tag. Thanks for the advice guys. I wasn't sure.
Kyle
Old Dec 1, 2005 | 10:49 AM
ivanribic's Avatar
ivanribic
A lot of guys will get confused by this because of the open carrier. If both tires aren't spinning evenly it'll mess up your calculations. Or you can always leave one tire planted on the ground, just jack up one side and spin it and then double the number of turns that it takes and this will be your approximate ratio. So if it took 1.5 turns exactly and the other tire was stationary you'd be at about 3:1, etc. Dennis advice about spinning 10 times is good advice. Anytime you're checking the ratio by eyeballing it, the more turns you use the more accurate you'll be.
Y2K1TON
1978 - 1996 Big Bronco
Feb 14, 2015 09:39 AM
IDIDieselJohn
Jun 18, 2014 10:51 PM
hustler54
1983 - 2012 Ranger & B-Series
16
Jun 23, 2013 06:33 PM
seminaryranger
Feb 23, 2010 01:06 AM
Storm
Sep 3, 2007 11:30 PM
