Check engine light 97 Ranger
Old Nov 30, 2005 | 12:41 PM
jecp's Avatar
jecp
I know I saw a topic on how to pull codes from a Ranger, and I can't seem to locate it. Please direct me to the correct post, or give a quick explaination. Thanks as always, for the help.
Old Nov 30, 2005 | 01:04 PM
05ranger's Avatar
05ranger
you can go to auto zone,or advance auto and they will check them for you for free..
Old Nov 30, 2005 | 09:07 PM
Ken00's Avatar
Ken00
You will need an ODB-II scanner for your year, the parts store is a cheap method.
Old Nov 30, 2005 | 09:32 PM
natebaker's Avatar
natebaker
Yep, Autozone has the OBD scanner you'll need. Make sure you talk to someone that knows what they're talking ab when you want parts. I went through a new EGR, a new EGR vacuum valve, and an IAC before I finally figured out the problem on my own. That put me at $140 worth of parts that they suggested before I figured it out myself.
Old Dec 1, 2005 | 04:26 PM
jecp's Avatar
jecp
Smile 97 ranger
I cheaped out. Removed the battery cable and let the CPU reset. Lights out, trucks running great, now I'll wait to see if was a fluke (I doubt it) or if the light comes back on. Thanks for the info. By the way, how much does an ODB-ll scanner cost? Can it be used on the 2002 Escape?
Old Dec 1, 2005 | 04:47 PM
RangerPilot's Avatar
RangerPilot
It'll prolly come on again. It may have just been a single event the engine noted and popped on. If (when?) it happens again, it'll pop the code and you can have it checked.
Old Dec 1, 2005 | 05:30 PM
Rockledge's Avatar
Rockledge
You can get an Actron OBD-II code reader from PepBoys for around $80.
Yes it will work on the '02 Escape as well as pretty much all OBD-II Ford, Chevy, and Dodge vehicles, for that matter.
Old Dec 1, 2005 | 06:04 PM
jecp's Avatar
jecp
As always, thanks for the info Rockledge. BTW, I installed manual hubs (auto locker issues last year) and it is the way to. $231.00 for the hub, spindle nut kit and socket to do it all. I haven't noticed an improvment in gas mileage, but I did notice an overall 4x4 performance. Now when it is in 4x4 mode, it is really in 4x4.
Again, thanks for the info.
