specs help
i have
f-150 1985 with fuel injection and power every thing and single cab with duel tanks.
i would like to know about the fuel mileage and the size of tanks
either would give you more specs than you'll ever need.
some folks will be able to give info on random questions like that, but if you pick up a manual, you'll have the info +some and most of what you need to do the repairs.
You have dual tanks, run one of them dry, (that's be a good time to replace your probably ancient fuel filter) then fill it up and see what the gas station pump says for total gallons. Then, drive on just that tank till it's dry again and calculate your mileage. EVERYONE's gas mileage is different. depends on type of engine, conditions, driving technique, etc, etc, etc.
By the way, I happen to look down into the bottom of my 2.5 gal read gas container, which I've had for years. To my amazement, a bunch of rather large pieces of crud...each like 2 or 3 mm. It is only opened when filling or emptying.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
i would like to know about the fuel mileage and the size of tanks.
MILEAGE: The EPA published this stuff. Gotta specify the transmission and engine size. Search this forum, there's been alot of references to the listed mileages.
TANKS: Ditto.
