Engine swap?
Old Nov 30, 2005 | 09:32 AM
maniacalchicken's Avatar
maniacalchicken
Engine swap?
Hi i have a 1988 F150 with a straight 6 and a manual tranny, can i swap that engine into a 89 F150 that has a 302 and use the auto tranny that is in the 89? Will the engine mount up correctly. Thanks for any help.
Old Nov 30, 2005 | 12:53 PM
andym's Avatar
andym
Yes, it will work fine. You'll obviously need to swap the whole engine, including accessories, wiring harness and computer.
Old Nov 30, 2005 | 01:55 PM
maniacalchicken
Yes the computer, wiring and acc. will go. Thanks for the help! =)
Old Nov 30, 2005 | 03:20 PM
radramrod2's Avatar
radramrod2
Just a reminder to use the correct flexplate for the six cylinder. The one from the 302 will not work...properly.
Old Dec 1, 2005 | 12:01 AM
EPNCSU2006's Avatar
EPNCSU2006
Also check on that automatic. If it's an E4OD, you'll need a six cylinder E4OD computer and the harness to match.
