Modifying
Old Nov 30, 2005 | 04:34 AM
ThaRain_GA's Avatar
ThaRain_GA
Question Modifying
How can this be done? Take a automatic 1991 4x4 Ranger and put in an manual transmission. Also how safe and reliable are body lift kits, are they worth the money? Thanks
Old Nov 30, 2005 | 04:21 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
To swap out the transmission, you will need a new fly wheel and pilot bearing to replace the auto flex plate on the engine. Also you might need a different starter because of the number of teeth on the flywheel. You will need a new clutch and brake pedal support bracket to hang the clutch pedal with the clutch master cylinder. You will need the clutch line going to the M/T, slave cylinder and throw out bearing.
You will need a engine control module for a manual transmission engine calibration. I think you also need to change the dust shield that goes between the engine and transmission from auto to manual. Of course the M/T will have to be from the same size engine and a 4x4 to accept a transfer case. I think the drive shafts don't need to be changed because they are transfer case dependent, rather than transmission dependent.
Old Nov 30, 2005 | 04:38 PM
natebaker's Avatar
natebaker
I think Pat covered everything, lol. I've never been a fan of body lifts, imo they make the truck look funny bc on the one's ive seen, the bumper stays still and the body goes up. I would go suspension lift. Also, I'm a big M/T fan. If there are many miles on your Ranger, I would go in the market for a new truck, or make sure that the A/T was getting ready to go so the expense could be justified.
