Sponsored by: Real Truck
marker lights
Old Nov 29, 2005 | 09:53 PM
bigblu250's Avatar
bigblu250
marker lights
Hello all...
Anyone know where I can find those three marker lights that the duallys have under the tailgate? Any help would be appreciated, thanks in advance.
Old Nov 29, 2005 | 09:59 PM
FortyFords's Avatar
FortyFords
Dealers,truck stops stores,fordparts online.
To name a few.I think Napa has it also in their catalogue.
Rich
Old Nov 29, 2005 | 10:06 PM
Neil's Avatar
Neil
Originally Posted by bigblu250
Hello all...
Truck-Lite is the OEM supplier for the ID lights on the rear of the Fords. Anyone that sells Truck-Lite can get it for you. It is a common part. If you order it from Ford, expect to pay over 40 bucks. Buy it from a truck-trailer parts outlet, you should be able to pick it up for under $20.00. I paid 14.00 for mine, but that was 5 years ago.
Old Nov 29, 2005 | 10:17 PM
rwilimo's Avatar
rwilimo
Does anyone make an led version?
Old Nov 29, 2005 | 10:21 PM
FortyFords's Avatar
FortyFords
Yes they make a led version.But the wiring will be a little different.some guys had to run seperate grounds to get them to work .This from memory about 2 yrs ago. vehiclelight.com or buytruckstuff.com
Rich
Neil's Avatar
Neil
There's some out there. A couple of years after I bought the Truck-Lite ID bar, I decided to upgrade the lamps. You can buy them from Truck-Lite also. They are a direct replacement for the incandescent lamps that come on the bar.
You might also be interested in these.....> http://www.blakesales.com/Innovative.htm
Old Nov 30, 2005 | 05:43 PM
bigblu250's Avatar
bigblu250
Thank you very much EVERYONE for the info, it is much appreciated
Old Nov 30, 2005 | 07:14 PM
2DLAKE's Avatar
2DLAKE
What Neil said...tapped into my license plate light and they work great. I got the red brake/marker unit. The light was to my door in 4 days, and I'm in Alaska!
Old Dec 1, 2005 | 05:02 AM
Bordaine's Avatar
Bordaine
Check my gallery for pictures of the Truck-lite LED 3 bar light. Truck-lite part number 35741R. The mounting holes are there and I taped into the plate light wire.
Old Dec 1, 2005 | 07:33 AM
nightmoves2's Avatar
nightmoves2
Napa part# 15745R $24.59+tax
Old Dec 1, 2005 | 09:30 AM
Bordaine's Avatar
Bordaine
15745R is not an LED light. It is the 15 series 3 bar light with a plastic bracket.You should be able to buy it from your local Truck-lite dealer for about $16.00. The same light bar with a stainless bracket 15741R should be around $15.00.
Old Dec 1, 2005 | 09:44 AM
dmp437's Avatar
dmp437
Grote model 49182-Red on mine featuring SuperNova L.E.D.'s It's bright, almost as bright as the brake lights. Being L.E.D. it draws 0.18 amps at 12 VDC so you can tap into just about anywhere. I tapped into the license plate lamps.
Old Dec 1, 2005 | 09:54 AM
refuse2's Avatar
refuse2
I bought mine at wal-mart and then painted the white frame to black to make it look better and I think that it was under $10 for the light and I had the paint.
T_199
Apr 25, 2014 05:04 AM
95350PS
Aug 28, 2012 06:48 PM
lucas restoration
Mar 25, 2005 06:20 AM
3992824
Mar 4, 2002 10:33 PM
wawii
Jan 12, 2002 05:55 PM
