bad engine leak
Old Nov 29, 2005 | 07:37 PM
DAN IN LOUISIANA's Avatar
DAN IN LOUISIANA
bad engine leak
i have a horrible oil leak showing up on the crossmember & the twin i beams and i cannot figure out where the leak is coming from.
can anyone help me?
Old Nov 29, 2005 | 08:52 PM
JD717's Avatar
JD717
What kind of fluids? oil, transmission fluid? brake, or power steering? coolant possibly? details,
Old Nov 30, 2005 | 05:50 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Dan in Louisiana, to Ford Truck Enthusiasts!
Enjoy FTE....see you on the boards.
Old Nov 30, 2005 | 08:57 AM
pricja00's Avatar
pricja00
he said "oil" but I'm betting on trans cooler lines.... is it red?
Old Nov 30, 2005 | 09:18 AM
toyscout2's Avatar
toyscout2
You didn't say what is leaking for sure. You said oil, but may mean transmission fluid? However, first go and get some engine cleaner from the parts store. Spray everything that is coated with oil and then hose it off. Once the bottom is clean, drive the vehicle for a mile or so and look for new leaking. Once the area is clean, the leak(s) should show up well. Also, being clean, it is much more pleasant crawling around under the truck trying to find the leak.
Old Dec 2, 2005 | 09:57 AM
turbocoupe5.0's Avatar
turbocoupe5.0
Other than the usual places like main seals & gaskets, here are a couple of other things to look for. I had a couple of bad oil leaks in my truck and because everything was so greasy under there, I didn't find them until I pulled the motor for other reasons. My oil pan had a patch of rust on it and the rust had made a couple of pin holes through the pan. The other leak was from the vent hole in hte mechanical fuel pump. If you have access to a steam cleaner, USE IT! Otherwise, use engine cleaner and a hose as suggested above. Hot water works better if you can get it. Try hooking up to your washing machine hookup. If you have a bad leak and you have been driving it that way for a while, you'll probably never find it until you get things clean.
Old Dec 5, 2005 | 01:39 AM
Lee Lichterman's Avatar
Lee Lichterman
If it is a 302, I would bet it is the rear main seal but might try valve covers first as they are also common for leaking. 302 seems to always get a rear main leak after about 80,000 miles. Doesn't hurt anything but does make a mess. I just changed mine finally a few months ago. Pretty easy but you have to pull the tranny back a bit to get in there.
Good Luck,
Lee
Old Dec 5, 2005 | 04:06 AM
rhodie's Avatar
rhodie
As Lee said, common problem is the valve covers and they're easy an easy thing to check first. They're not torqued down much and have a tendency to loosen up after a while..............
waystro
Jul 20, 2013 06:40 PM
Windsetter
Aerostar
18
Nov 21, 2010 03:29 PM
phoneman91
Oct 28, 2006 08:51 AM
cade
2004 - 2008 F150
Jul 21, 2005 06:12 PM
95mazdab2300
1983 - 2012 Ranger & B-Series
Jan 7, 2004 05:21 PM
