What motor?
Old Nov 29, 2005 | 07:30 PM
pokerpuller's Avatar
pokerpuller
What motor?
Last night i bought a 460 to put in my 78, but its from a lincoln, so of course the mounts don't match up. All the mounts i could find online are for conversion kits. See when i bought my 78, it was without motor, and i was told that it came from the factory with a 460. Since then i have learned that the guy i bought it from is probably one of the least credible people on the planet, sooo i was hoping somebody would know what motor these mounts are for. Thanks.
-kit
http://i6.photobucket.com/albums/y23...z/100_2716.jpg
http://i6.photobucket.com/albums/y23...z/100_2718.jpg
Old Nov 29, 2005 | 07:32 PM
ford390gashog's Avatar
ford390gashog
look like 351m/400
Old Nov 29, 2005 | 07:41 PM
RTM's Avatar
RTM
I don't think those are 351M/400 mounts. It looks like you are missing the block mount and they look alot like the 460 mounts I have for my 78 bronco wich has a custom bracket that allows me to use these mounts I speak of. They are stock 4x2 460 mounts but keep in mind that a 4x4 is a different animal.
Old Nov 29, 2005 | 07:46 PM
pokerpuller
alright thanks guys. oh and a little off topic, but np205 is mated and np203 is divorced right?
-kit
Old Nov 29, 2005 | 10:43 PM
satx77stepside's Avatar
satx77stepside
Jump in & correct if I'm wrong, but I believe the NP205 can be mated or divorced. The NP203 is full time & the NP205 part time.
Old Nov 29, 2005 | 10:46 PM
pokerpuller
ohhh. what are the advantages/disadvantages of having a divorced vs. mated t-case?
-kit
Old Nov 29, 2005 | 10:48 PM
satx77stepside
THAT, I don't know.
Possible advantage to mated would be less driveshaft angle than a divorced case?
Old Nov 29, 2005 | 11:46 PM
brown79's Avatar
brown79
its off topic but from what i have heard lincoln exhaust maifolds will hit the frame on one side
Old Nov 30, 2005 | 05:17 PM
RTM's Avatar
RTM
Truck manifolds are 2.5, I think and cars are 2.25 or something like that. Either way a truck manifold has the larger exhaust exit. The truck manifold on the pass. side turns down and inward more than the car manifold so the car manifold will hit the frame. I know this first hand. I have also seen the frame crack where people have cut the frame to clear the car manifold.
I don't think the 203 ever came in a divorced set up and it is a full time case which runs by way of a chain. Not the strongest set up to have. The 205 came divorced and attached and is gear driven which makes it a much stronger case and is used over the 203, for off road use. People do use parts from the 203 to make a doubler t-case set up. The t-case ends up with two shifters.
Old Nov 30, 2005 | 05:31 PM
Mil1ion's Avatar
Mil1ion
429/460 mounts are 3-piece mounts.
The insulator gets two HUGE bolts go through them to secure the mount.
Here's an illustration for the 460 truck engine mounts.
Old Nov 30, 2005 | 05:32 PM
to many oft's Avatar
to many oft
203 and 205 both were made divorced and mated
had a 75 f250 with auto trans and divorced 203 (gas hog!)
as for the exaust, cheaper to put truck headers on it.than you don`t worry about hit problems or broken frame
as for the mount they look like 6 cyl mounts for 2x4
Old Nov 30, 2005 | 07:02 PM
LxMan1's Avatar
LxMan1
Those look kinda like my 460 mounts. It's been awhile since I put the engine in. The pad that bolts to the block is different from a car to a truck. I couldn't use any of the car mounts.
Old Nov 30, 2005 | 09:29 PM
pokerpuller
Thanks a ton. You guys are awesome, especially Mil1ion for the diagram.
-kit
Old Nov 30, 2005 | 09:32 PM
pokerpuller
does anyone know the distance from the back of the trans to the rear yoke centerline on a mated 205?
-kit
Old Dec 1, 2005 | 04:57 AM
RTM's Avatar
RTM
-kit
That depends on which set up you're asking about. There's a short one and a longer one. I have both the short and long adapters and a C6 trans so I could measure both for you. Also this is a big block C6 set up, correct?
