Aerostar Ford Aerostar
1992 ford aerostar
Old Dec 2, 2005 | 07:28 AM
96_4wdr's Avatar
96_4wdr
http://www.rockauto.com/ref/Cloyes/Detail.html?95261.jpg
http://www.rockauto.com/ref/Cloyes/D...html?95345.jpg
http://www.rockauto.com/ref/Cloyes/D...ml?94172SA.jpg
Old Dec 2, 2005 | 08:12 AM
VanGo's Avatar
VanGo
I stand corrected.
Thanks 96.
-Justin
Old Dec 2, 2005 | 04:16 PM
96_4wdr's Avatar
96_4wdr
we are all still learning from the great pushrod V6's and Aero vans Ford built in the 90's,,,really built Ford tough, economical on fuel and low cost to repair/service
too bad Ford DIDn't....another 7,500 layed off and 5 plants closed...some of the newest most modern they have....will be no Ford light truck production in USA in 5 years if this continues
good bye F150>F350 and Ford vans
Old Dec 2, 2005 | 04:51 PM
ken1mod's Avatar
ken1mod
I just cleaned the inside windshield of my aero. Lightly brushed headliner with soft rag. Headliner disintegrated. Dear FOMOCO we remember this stuff when we buy new cars. Why don't they know this stuff?? Please return to the quality of yesteryear, when american cars were the standard of the world.
I hate to buy foreign cars but, dammit sometimes they are simply better built.
Grumble, grumble, hole in my headliner.
Ken
PS. I'll get over it.
Old Dec 2, 2005 | 05:22 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
ok so with an auto timing chain tensioner, you shouldnt have the old problem of chain slack retarding your cam like in the older engines, right? crank/cam timing should be right on regardless of slack (cause theres none) right? i like the fact that the 4.6's and such were built with chains and tensioners. most ohc's of the generals and other manufacturers from that era had krappy belts that always die at 60,000 miles, sometimes takin out the valves.
Old Dec 2, 2005 | 09:43 PM
VanGo's Avatar
VanGo
Cam timing will still be affected if the timing chain is worn and stretched. The chain in effect becomes longer as it stretches. Tensioners can only limit the chain from flopping and digging into the cover and perhaps jumping a tooth on one of the gears. It can't correct for a longer chain.
In other words, the timing gears that were once aligned at TDC at the time of assembly will not be on the TDC marks once the chain stretches and becomes longer. The upper cam gear will lag behind the lower "drive" gear. Does that make sense?
Old Dec 2, 2005 | 09:51 PM
ken1mod's Avatar
ken1mod
OK, timing changes. What effect does that have? More low end torque? timing sets often have the ability to set them up at + or - 3 degrees depending on how one wants to effect the tuning of the engine. I know it is different than spark timing (more advanced short of detonation , the better) I never understood cam timing.
Ken
Old Dec 3, 2005 | 12:16 AM
oldfordtrucksrule
retarding the cam should give u more power on the top end, losing some on the bottom. and vice versa
76_100
17
Mar 26, 2016 06:02 PM
lafermedavid
16
Jun 1, 2014 07:50 AM
old76er
Nov 11, 2009 09:26 PM
Nod
Nov 22, 1999 11:44 AM
