Help I.D. this...
Old Nov 29, 2005 | 03:02 PM
BandBFord's Avatar
BandBFord
Help I.D. this...
I have the opportunity to purchase (for very little money) an older F100 to compliment my growing Ford collection. The truck has been owned by the same fellow for the past 20 + years. Can anyone help my de-code the information on the door?
Thanks ahead of time for any help...
Serial # F10JK710039
Color WB
Body #281
Trans A
Axle 09
Old Nov 29, 2005 | 09:36 PM
Putt's Avatar
Putt
It depends on the year of your truck.
It looks like a 240, 1 bl. carb engine with a 3 speed Ford manual trans if a 1965 F100.
The K in the serial number denotes which plant built the truck, unfortunately I don't have a chart of the plants! The rear axle is either a Ford 9"(no removeable rear cover) or a Dana 44(rear cover), I do not have the axle code info.
HTH
Old Nov 29, 2005 | 09:52 PM
BobbyFord's Avatar
BobbyFord
Axle ratio is 3.70, 9"
K = Kansas City Plant
Truck was built in July, '65
Old Nov 29, 2005 | 11:10 PM
Putt's Avatar
Putt
instig8r63- I am curious as to how you are able to determine the build date from the serial number.
Old Nov 30, 2005 | 05:40 AM
banjopicker66's Avatar
banjopicker66
Putt: The "consecutive number" is the serial number. Ford set aside blocks of consecutive numbers to use each month, and those were further subdivided among the factories.
Old Nov 30, 2005 | 08:26 AM
Putt's Avatar
Putt
Ahhhh, I see. Thanks, banjo.
Old Nov 30, 2005 | 11:35 AM
BobbyFord's Avatar
BobbyFord
I don't know if I can post this link, but here goes, I hope it ain't against the rules.
http://f100fever.topcities.com/specs6166.html
Old Nov 30, 2005 | 12:59 PM
BandBFord's Avatar
BandBFord
Thanks for everyones help...
