Just Purchased - Have Question?
Old Nov 29, 2005 | 02:38 PM
wlmanning's Avatar
wlmanning
Question Just Purchased - Have Question?
I just purchased a 1992 F-150 Standard Cab, 4X4 5.0 ltrs. I notice that when driving in 2 wheel drive, it feels kinda like the brakes are on or something is resisting accelleration (push/pull type of feeling). When driving at normal speeds on the highway and I let my foot off of the gas, instead of coasting freely, I begin to rapidly reduce speed without pushing on the break pedal.
Is this normal or should I look into something else? I have never owned a 4X4.
Old Nov 29, 2005 | 02:45 PM
cody123's Avatar
cody123
It could be your brakes are out of adjustment most likely the rear brakes. Is the transmisson a standard or automatic? and does the truck have manually locking hubs give us more info to go on.
Old Nov 29, 2005 | 03:24 PM
wlmanning's Avatar
wlmanning
The transmission is automatic. How can I tell if I have the manually locking hubs? Just picked up Friday of last week.
Old Nov 29, 2005 | 03:25 PM
andym's Avatar
andym
I would jack the truck up and try to spin each wheel. You probably do have a brake problem going on, but it will be tough to figure out which one unless you narrow it down.
Old Nov 29, 2005 | 03:53 PM
wlmanning's Avatar
wlmanning
Thanks. I will pull her into the garage when I get home and attempt to spin each wheel.
Old Nov 29, 2005 | 05:22 PM
cody123's Avatar
cody123
look at the front axle hub if there is a circular center peace It will twist back and forth in little writing say lock, unlock make sure there not in the lock postion. If the axle hub is just has a cap over it then nevermind this there not manual hubs.
Old Nov 29, 2005 | 07:02 PM
wlmanning's Avatar
wlmanning
cody123 - Thanks. I finally got a chance to look at those closely and saw that they are automatic. However, I noticed that the transfer case is making a humming sound. Have any idea what that can be? Also, I don't believe it is the breaks because on my way home, I placed it in neutral and it coasted fine. However, when I put it back in gear, deceleration began to occur greater than what if feel is normal. Any and all suggestions, ideas are welcome. Thanks again.
Old Nov 29, 2005 | 07:08 PM
Popa Tim's Avatar
Popa Tim
How does it shift when driving? Is it shifting hard? Do you drive in Overdrive if you have it?
Whats the tranny code, you can find it on a sticker in the drivers door jam.
Old Nov 29, 2005 | 07:20 PM
wlmanning's Avatar
wlmanning
The tranny code is "E". I do drive in Overdrive all the time. It's not like I have to force it to shift gears when driving, but it seems like it takes more RPM's to shift than normal.
Old Nov 29, 2005 | 07:25 PM
Popa Tim's Avatar
Popa Tim
Might I suggest you pull your codes then. I think you may be in "limp home" mode. The codes will help tell what to check and fix.
You can pull them yourself, visit http://fordfuelinjection.com/?p=13 to learn how. All you need is some jumper wire or a paperclip.
OR you can spend $30 and get a ford code reader from your autoparts store or walmart. Grab a $15 haynes or Chiltons manual while your there unless you plan on gettng a factory service manual.
Post your codes and we'll be glad to help figure them out.
Tim
Old Nov 29, 2005 | 07:39 PM
wlmanning's Avatar
wlmanning
I don't quite know if it is "limp home" mode because I have no problem getting around. I may burn more fuel than normal, but there are no indications that the vehicle is going to stop operating at any moment. I will probably invest in a reader though.
Old Nov 29, 2005 | 07:43 PM
Popa Tim's Avatar
Popa Tim
limp home mode runs well and is usually noticed by shifting harder than normal and poor gas mileage, since you haven't had your truck long you may not know what normal is. Is should be very car-like, smooth!
Your tranny is an E4OD, same as mine and my truck coasts great! I DO beleive you have a problem. I don't think you are getting into OD, getting stuck in 3rd on the highway. Lets see what the computer thinks, its very good at finding them :-)
Tim
Old Nov 29, 2005 | 07:52 PM
wlmanning's Avatar
wlmanning
Popa Tim - I am going to take it for a spin real quick. Are you saying that I should be able to shift from third to overdirve (or fourth) gear when on the highway? If so, I will let you know the results of my test shortly.
Old Nov 29, 2005 | 07:55 PM
Popa Tim's Avatar
Popa Tim
On the 92 I think the OD off button is on the dash instead of on the shifter **** like in my 94, but yes, you should be in OD at around 45mph (unless accelerating) so turning off OD on the highway should produce a noticible shift in the transmission and an RPM increase in the engine.
Old Nov 29, 2005 | 09:37 PM
russell56443's Avatar
russell56443
My 88 F250 HD,351,auto 4x4 has a rear brake sticking problem that I hav'nt had a chance to fix yet.
I can get out when it sticks and tap the brake backing plate(not sure of the name)with a hammer and the shoes release for another 50 to 100 miles or so and then they stick again?
I plan on fixing it as soon as I can find a heated garage ect... to work in,It's cold here in Minnesota lol,
Russell
