help
Old Nov 29, 2005 | 04:27 AM
BIG-COUNTRY's Avatar
BIG-COUNTRY
help
i have a 81 f150 302 and when i dont have my foot on the bake it makes a hising sound but it stops when i put on brakes could anyone tell me what causes this and how do i stop it? thanks
Old Nov 29, 2005 | 01:19 PM
Lazy K's Avatar
Lazy K
I think you have a vacum leak somewhere. You could try pinching the vacum pipes until the hissing stops, you will then know you are near the leak.
Old Nov 29, 2005 | 02:12 PM
turbo2256's Avatar
turbo2256
Inspect the check valve that plugs into the brake booster. Air should flow only one way through it. If it flows both directions its not keeping a vacuum on the brake booster. There may be other places that vacuum could be leaking but the brake is often over looked.
Old Nov 29, 2005 | 02:30 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Just to add The rubber grommet that seats and seals the check valve could be bad, as well as The brake booster itself can be leaking. there is a rubber seal inside the passenger compartment on the brake booster, that the linkage goes through. It could be leaking there.
just my two cents.
Old Nov 29, 2005 | 05:53 PM
subford's Avatar
subford
My vote is for a bad brake booster, you need to replace it.
Had the same thing in my 1983.
Old Nov 29, 2005 | 06:01 PM
smiller4597's Avatar
smiller4597
Usually if you hear the vacuum leak from inside the cab the booster is leaking and needs to be replaced. Dont wait too long as when the booster gives out all together breaking requires about a ton of weight on the pedal to make it stop and at high speeds this becomes a real problem!
Old Nov 29, 2005 | 06:25 PM
BIG-COUNTRY
about how much does a booster cost?
Old Nov 29, 2005 | 06:36 PM
smiller4597
dont remember I think you have to buy the master and booster all together could be around $200
Old Nov 29, 2005 | 06:54 PM
81-F-150-Explorer
You can buy the master and booster seperate or as whole unit.
If your brake fluid is dirty, or you have doubts about the master cylinder, then replacing it, changing the fluid, when you replace the booster is a good idea.
The booster or booster / master cylinder combination averages anywhere between $79 and $150 dollars depending on where you go.
While you are at it. Check the brake lines, hoses, wheel cylinders, pads, shoes, etc.. for damage, wear, leaks, cracks, etc...
While doing the master cylinder, and brake booster, it's much simpler to replace these components, and less work in the long run. Imo
good luck.
